Belt squeal after UR pulley installed
Old 10-17-2008, 11:00 AM
BigBadTL's Avatar
I just installed the stock diameter UR crank pulley and replaced all the belts as well as the tensioner and pulley component...I used all OE equipment from the local dealership. I'm getting belt squeal on start-up only in the morning, but it is fine during the day and when driving. After doing some research, it seems I should be using the GATES belts and that should stop the squeal...am I correct?
Old 10-17-2008, 11:56 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Try spraying a bit of belt dressing on the belts. See if that fixes the problem or see if it comes back. If it does try changing the belt.
Old 10-17-2008, 02:26 PM
wham bam thank you ma'am
Rajca's Avatar
after i installed my ur pulley i had a squeal afterward. used belt dressing and helped then it came back, changed the belts and its all good now.
Old 10-17-2008, 02:36 PM
BigBadTL's Avatar
^^did you folks use the GATES belts?
Old 10-17-2008, 02:43 PM
Rajca's Avatar
i used the belts from auto zone.
Old 10-17-2008, 02:47 PM
EL19's Avatar
duralast?
Old 10-17-2008, 03:56 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Is the torque on the new crank pulley bolt set at 181 foot pounds?
If its not on tight enough- there can be a mis-alignment of the belt and cause a noise
iirc some 03s got a new pulley and timing belt on recall- a misalignment was wearing out the belt early
Old 10-17-2008, 04:03 PM
Rajca's Avatar
i think its duralast, thats what autozone sells so i guess that thats what i got.
Old 10-17-2008, 04:44 PM
BigBadTL's Avatar
mine's a 2002 TL-S, so I don't think the recall applies, but I did hear about it before...
I just picked up the Gates belts from NAPA, so hopefully they will take care of the problem when the're installed on Monday.
Old 10-17-2008, 08:31 PM
Former Sponsor
Excelerate's Avatar
1. Check the tension on the belt.
2. Make sure it's a Gates Belt
3. Apply belt dressing
4. Replace it if it's worn or not a Gates belt since they work best with the UR aluminum pulleys.
Old 10-22-2008, 10:19 PM
BigBadTL's Avatar
Quick update for folks you may read this thread in future...if you plan to run a UR stock size crank pulley, you MUST use the Gates belt. I was experiencing squealing, and a low rpm ticking noise with the stock size OE belt. This was after replacing the tensioner/pulley and both belts using the the Honda/Acura brand. It turns out that a brand new Gates serpentine belt is about 3/4" of an inch smaller in diameter than a brand new Honda/Acura serpentine belt. When using the UR pulley, the Honda/Acura belt (because it is longer than the Gates belt) fully extends the tensioner, causing both a low rpm ticking/rattling noise and a periodic squeal. My mistake was believing that since both brands list that model belt as the stock size replacement, that it wouldn't matter which one I used.
In my searches about this problem, it wasn't ever fully explained why the Gates belt had to be used, so hopefully this will help other folks out in the future.
Old 10-23-2008, 01:13 AM
Your Garage
DC3328's Avatar
where do u get a Gates belt?
Old 10-23-2008, 02:08 AM
Former Sponsor
MrHeeltoe's Avatar
+1
But toss out that belt dressing idea. That stuff usually works for the short term only, as mentioned above.
Old 10-23-2008, 02:09 AM
Former Sponsor
MrHeeltoe's Avatar
We get the timing belts:
http://www.heeltoeauto.com/Gates-Tim...-pr-63565.html
And we get the pulley belts for NST TSX kits.
If you can shoot me a belt number I can get the belt for you no problem.
Old 10-23-2008, 07:01 AM
01tl4tl's Avatar
call local parts stores and ask if they sell gates belts- you will find one fast
Old 10-23-2008, 08:56 AM
BigBadTL's Avatar
I got mine from NAPA...their brand is manufactured by Gates.
Old 10-23-2008, 01:05 PM
Former Sponsor
Excelerate's Avatar
http://store.excelerateperformance.c...s/b-10643.aspx
Or buy them from Napa b/c Napa has Gates make their belts, as was mentioned below.
Old 11-19-2008, 10:22 PM
MP90 uninstalled
jproy's Avatar
I have used all gates belts and used several different UR pulleys of both OE size and under drive size on the CLS. All of them had a low RPM squeal that chirped with every firing of the cylinders especially when the AC is on after I put about 1500 miles on the belts. Each pulley was different and all have had only new belts with the pulley install. I have even tried changing the belts again. As always, in about 1500 miles the squeal comes back. It is annoying as hell. Sometimes I hear it in my sleep. Do not use belt dressing. It causes more problems in the long run. I have the UR under drive on now and it is really pissing me off. I may try a belt one size smaller than specified for the UR UD pulley. I have also replaced the entire tensioner with a new OE unit all three times I installed a different pulley. As soon as I went back to the stock pulley twice the noise was completely eliminated. The improvements with the pulley are great however.
Old 11-23-2008, 01:27 PM
BigBadTL's Avatar
please post what size belt you decide to try...so far, mine has been good, with no squeals or other noises...
Old 11-23-2008, 01:31 PM
MP90 uninstalled
jproy's Avatar
I have not done it yet and I forgot to mention in the post above that the noise is only at >1500rpm when the A/C compressor is on.
BoricuaTL
04-08-2016 01:08 PM
2012wagon
09-29-2015 04:21 PM
mossman77
1/2G MDX (2001-2013)
18
09-16-2015 12:21 PM
iCrap
09-11-2015 06:21 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Belt squeal after UR pulley installed
