Base to Type S upper intake 03 TL
Old 07-03-2014 | 08:29 PM
Racers'edge's Avatar
Hi, I'm about to install a type-S upper intake manifold on my base TL, I shop also for the type-S ECU, maybe bigger cc injectors along with fuel rail and fuel pump, I've already got AEM CAI which I know I'll have to cut a couple inch to fit the bigger(longer) throttle body, also equipped with DC headers...
But my question is: do I have to change more things, I fear I would be short of connectors for this new piece... and if I keep my fuel system as is, would it be enough ?
If Somebody already done this Mod, I would appreciate some advices on that job ;-)
Old 07-03-2014 | 09:03 PM
Skirmich's Avatar
Why would you mess with the VTEC threshold and Redline on a stock J32A1?
Stick with your ECU until you have a proper J32A2 Engine since internally isn't the same as the A1.
justnspace (07-04-2014)
Old 07-04-2014 | 11:52 AM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
You will need different bolts, studs, and studs where the intake manifold bolts to the runners. The tl-p has shorter ones than the type s. You won't have to cut your intake tube. Don't get bigger injectors, fuel rails, fuel pump, or a type s ecu, you won't need it till you won't need it because you won't even come close to maxing out what you have with those mods and the j32a1 engine.
The following 2 users liked this post by Stephen00TL:
justnspace (07-04-2014), Racers'edge (07-04-2014)
Old 07-04-2014 | 04:55 PM
fsttyms1's Avatar
Don't waste your time or money on different fuel injectors, rail, pump or ecu. You won't need them. And honestly, I wouldn't waste my money on the type-s intake either. I would get a 09+ Im and larger tb
The following 2 users liked this post by fsttyms1:
Old 07-04-2014 | 05:03 PM
welp, looks like my job here is done.
Old 07-04-2014 | 05:24 PM
fsttyms1's Avatar
Keep up the good work
Old 07-04-2014 | 07:50 PM
Smile
Thanks for your advices, I just saw that on type S there is a different head for the j32 (I remember seeing somewhere that J32A1 and J32A2 were only different on the intake manifold and exhaust...), so just changing the intake manifold will be almost useless without a head change... I've already bought the intake, but if is to gain 5 HP I won't do the swap... I know that the best intake manifold swap for my TL is the 09, but I hardly can't find one, or too much pricey I'll maybe polishing my TB to get the most out of it...
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
kmarqueling
10-03-2015 01:14 AM
C2CuSn07 TL
09-11-2015 06:54 PM
Quick Reply: Base to Type S upper intake 03 TL
