After market pulleys
Hey guys! My drive pulley is rattling and my friend told me to buy a new one and he'll replace it for me. However, instead of buying one from the dealership, I have an excuse to buy an after market one. Any suggestions and where I could go to buy one?
Sorry if this is in the wrong thread. If it is, could an admin please move it to the right one. I figured it would be a performance mod.
Thanks!
Thanks!
Honda Nation
Scooby doobie crusin
Your crank pulley shoundnt be making noise. Are you sure its not the tensioner. The only pulley worth spending money on is the crank pulley
Thanks! I'll check it out.
I believe it is the tensioner, but the pulley shakes a little at around 1.2k rpm and makes a noise. I'm just finding an excuse to modify my car. I figured if he changes it out, I might as well put a better one back in right?
The website says 12-16hp. Does that come out to about 2-4 at the wheels?
I'm willing to bet you wouldn't actually notice a difference... but then again if you have to change it anyway why not??
I would say that if you went from 200 to 205hp it adds it. By your statement the same can be said for a intake exhaust and headers. They dont add hp, they free up power that was lost due to the restriction.
Just curious, does adding an underdrive pulley negatively affect any other parts of the car? Alternator, power steering, a/c, whatever else the belt drives...?
Roughly what percentage would the reduction in belt "rpm" be? Like 5% or 50%?
UR makes 2 pulleys. One a underdrive and one a standard size. The Underdrive only effects things such as large stereos. If you have one of those then get the stock size (still much much lighter than the stock pulley)
what do you mean by large stereos? i have a w6 and a jl 500 mono block. should i get stock size or underdrive
I had my installed by a performance shop. They only charged me $50 for 1 hour of work. Took them like 45 minutes since they had a very powerful impact wrench. I think the nut/bolt is torqued down to ~181ft/lbs.
