Aem V2
Originally Posted by 99bluetlwtt
The Intake doesn't go stright on the trottle body. I think you can fit just clamp it and the trottle and intake doesn't have to be the same size.
Originally Posted by TLMugen
The rubber coupling is a snug fit on the TL-P TB, it won't stretch over a TL-S TB.
Is it possible then to get a bigger rubber coupling from Home Depot or something. I mean it's a pipe, there has to be a way to fit.
yes, there is.. If you really want I'm sure you can get a coupling to connect the v2 to the throttlebody.
If you want a quick fix....
- Get a roll of rubber tape from 3M. This tape is for high current wires and has a thin plastic film that peels off of it.
- Put the rubber tape onto the piping of the V2 where it meets the throttlebody (TB). Increasing the diameter of the V2 pipe.
- Get a rubber coupling that fits the Type-S TB, just like the one that would come in a type-S CAI kit.
Now with the V2's pipe diameter increased (to the size fo the tpye-s TB) the coupling will fit perfectly, and the rubber tape will make an air tight seal, when the metal clamp tightens down.
Jul 16, 2017 07:33 AM
