AEM FIC / Fuel-Ignition Controller
Old Apr 11, 2009 | 03:19 AM
adamlee05's Avatar
Thread Police Chief
Did a quick search but nothing interesting turned up. I might have missed it though.
Anyone looked into the AEM FIC for tuning or know much about it? Seems pretty solid in theory. Discuss
Old Apr 11, 2009 | 05:12 AM
NVA-AV6's Avatar
BANNED
Works well, I have several J series vehicles using them now without issues including a J36 powered 7th gen AV6 that is producing 302WHP and 280WTQ, they only drawback I have found for the unit is that it will only retard timing, not advance. Other than that it is a great bang for the buck especially if teamed with a UGEO gauge which can be hooked into the FIC to provide AFR as part of the datalog......
Old Apr 11, 2009 | 09:16 AM
Rajca's Avatar
wham bam thank you ma'am
a couple cl have been running an emag. with no problems.
Old Apr 11, 2009 | 10:51 AM
EL19's Avatar
rare to see u around these parts
Old Apr 11, 2009 | 11:18 AM
NVA-AV6's Avatar
BANNED
Yeah, but I am getting more of you guys coming around....
Old Apr 11, 2009 | 02:28 PM
adamlee05's Avatar
Thread Police Chief
About time you showed up Paul. Stick around more
I just ask because I'm going to need somethign to tune the engine when I'm done with it. It's basically the same as Jcharged - 11:1 J35A4 w/ CL-S heads and CL-S 6mt. I'll be running it off a TL-P ECU most likely, so would you recommend using the FIC over E-manage for this? Also, would I need to use an aftermarket FPR?
Old Apr 11, 2009 | 02:33 PM
Rajca's Avatar
jcharged is using an aftermarket fuel pressure regulator
Old Apr 11, 2009 | 03:44 PM
adamlee05's Avatar
Thread Police Chief
yes but hes not using an FIC
Old Apr 11, 2009 | 07:37 PM
NVA-AV6's Avatar
BANNED
FIC is cheaper and works for me at least, just installed another one today with no issues including changing out the stock injectors with RDX injectors....
Old Apr 11, 2009 | 09:40 PM
sinfulj32's Avatar
does it happen to bypass the rev limit?
Old Apr 11, 2009 | 09:42 PM
adamlee05's Avatar
Thread Police Chief
Just a fuel and timing controller, it intercepts PCM/ECU injector and coil signals and modifies them. Doesn't actually mess with the ECU itself IIRC
Old Jul 15, 2009 | 04:01 AM
rtatsutani's Avatar
Never had a clean run
Do you guys know if our car's ECU override's the AEM FIC? I know it overrided my emanage blue so I kept having to pull my battery to get it to run at an optimal level.
Old Oct 13, 2009 | 05:12 AM
rtatsutani's Avatar
Anybody have any long term success stories with the AEM FIC?
Old Oct 14, 2009 | 11:53 PM
DC3328's Avatar
Your Garage
read through this thread, he really knows his AEM FIC
https://acurazine.com/forums/2g-cl-2001-2003-50/mp90-supercharger-retrofitted-mp62-comptech-kit-694376/
Old Oct 14, 2009 | 11:54 PM
DC3328's Avatar
Your Garage
what the hell happened to adamlee?
Jul 16, 2017 07:33 AM
adreano17
Sep 29, 2015 08:48 AM
kingbharj
Sep 25, 2015 07:25 PM
