99TL Fuel economy suggestion
Old 08-21-2010, 09:47 AM
UNCatTech's Avatar
Hello, I have a 99 TL and the miles per gallon that the car gets is slowly going down.
Any suggestions for budget mods that might help with fuel economy?
Thanks.
Old 08-21-2010, 01:52 PM
02TL4ATL's Avatar
ngk iridium ix, air filter, seafoam, tire pressure, etc
Old 08-22-2010, 12:50 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
clean the EGR port--gets plugged and cars runs poorly
based on the experience of our megamoderator fsttyms1- with 350,000 MILES!! and climbing on an 00
every 75kmiles the intake manifold needs to come off and clean the egr ports out with a wire coat hanger and solvent/carb cleaner
see DIY section for details
call acura to see if yours was ever done under recall to install a thing in the egr passage-99s only
1-800-382-2238x5 need cars vin
they only do it once then its on you
same thing for 99 ignition switch- see if thats been done on recall
Old 08-22-2010, 12:52 PM
01tl4tl's Avatar
how are your spark plugs? 100k is acura dream on longevity
60-70kmiles and they are pretty worn out- enough to merit replacement with the correct ngk iridium spark plug
platinum was stock- iridium= gen3 uses them stock, and its an upgrade for us
Old 08-24-2010, 10:46 PM
twill220's Avatar
also use 91/93 oct
using 91/93 octane with lucas fuel treatment will significantly increase fuel economy. recently on a trip from upstate ny 2 northern va i ave about 33-35 mpg. not bad for a 99 w/ 190k. even after city traffic i almost got 500 miles from a full tank. ok 468. i will attempt to clean my ports after reviewing the diy posts
joflewbyu2
08-18-2019 10:38 PM
baelim
05-10-2018 09:53 AM
joflewbyu2
10-08-2015 11:16 AM
kb1rl
09-30-2015 10:17 AM
c1souk
09-28-2015 11:20 AM
Quick Reply: 99TL Fuel economy suggestion
