6 speed questions
Old Apr 26, 2014 | 06:07 PM
castls's Avatar
BANNED
6 speed questions
I want to begin locating all parts I need before my transmission goes all the way out, I plan on using a tl 6 speed out of an 04, other than that what else is required? any help is greatly appreciated.
Old Apr 26, 2014 | 07:02 PM
Skirmich's Avatar
iirc that trans doesn't have an LSD..
I believe only the TL-S 3G has an LSD.
Old Apr 26, 2014 | 08:00 PM
fsttyms1's Avatar
The trans from the TL wont work with the CL-S ecu so unless you plan on figuring out all the stuff needed to get your current ECU to work with a manual start looking for the CL-S6 trans.
Old Apr 26, 2014 | 08:28 PM
Skirmich's Avatar
^ Are the sensors so different?
I thought a sensor swap ala AV6 AUTO would do
Old Apr 27, 2014 | 02:28 PM
fsttyms1's Avatar
The 04 tl doesnt have the crank pickup sensor location on the trans like the CL does.
Old Apr 28, 2014 | 02:18 PM
AznWay's Avatar
These only 2 way you can use 04-06 6speed TL. First way is with Richvie module an 2nd way is with custom harness so you can run 04-06 Tranny with CLS6 ECU.
Old Apr 29, 2014 | 08:28 PM
Karanx7's Avatar
Unregistered Member
All Acura manual transmissions have LSD. Honda ones do not.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
drone619
Jan 26, 2016 07:09 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
