*Engine Cleaning Help*
Old Mar 1, 2006 | 08:42 PM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
alright guys i got the basics down packed i just need to know exactly what needs to be covered up so it doesnt get wet......if possible can you post pics of what needs to be covered....thanks this will be my first time doing this and i dont wanna mess anything up
Old Mar 1, 2006 | 08:54 PM
Blazin_TL's Avatar
Registered User
if you plan on hosing down your engine bay.. i dont think thats a good idea.. if any of the electrical wires/plugs get wet you could cause a short.. even if you disconnect the battery you still dont know if any water got to any plugs
Old Mar 1, 2006 | 09:06 PM
RickRoush03's Avatar
RickRoush03
dude, just hose the fugger down, preferably with a cold engine, but i wet her down, take my mit i use on the wheels, wipe down the major areas, rinse again and then run the car to let the heat dry the block etc so no rusting, done this to all my cars, bikes, no problems. now, if you freakin flood the engine then you'll have a problem, but when you drive in the rain its the same thing!
Old Mar 1, 2006 | 09:16 PM
demolition_x's Avatar
Agean Blue Bishes
get a thing of engine cleaner foam stuff. spray it where necessary.
hose it off when it defoams.
then i think the trick is use some tire shine stuff on it for it to look shiny
Old Mar 1, 2006 | 09:25 PM
Future JDM Whore
thanks fellas so according to rickroush03 you dont cover anything before wetting the engine area???
Old Mar 1, 2006 | 09:28 PM
Future JDM Whore
alot of people hose it down and nuttin has happened....all they did was cover the electrical things
Old Mar 1, 2006 | 09:42 PM
sbuswell's Avatar
I need 2 more gears
the safest way is to wrap all plugs and grounds well. disconnect your battery and cover it with a couple plastic garbage bags then use the foam stuff(can't remember name of it, someone else help here). Wait a while until it kind of disintergrates and then hose it off use a light spray, don't go full blast. Then wipe everything down with a MF towel and blue shop towels(paper towel roll but blue). They soak up grease and oil better than anything IMO. Then use a detail spray if you like on the engine cover. Armor All works fine for engine cover and other plastic pieces to make them shine nice. you get the old armorall residue, but not a big deal. Then take off wrap you used for the plugs and take plastic garbage bag(s) off battery reconnect and enjoy your clean engine bay. Also use some nice wax on the paint and it will really stand out. Now I have to do my car again in the spring. Have fun!
Old Mar 1, 2006 | 10:06 PM
Future JDM Whore
^^ thanks alot man im gonna do it once it gets warmer
Old Mar 1, 2006 | 10:14 PM
fsttyms1's Avatar
Ive never undid any thing or covered any thing before in my life. Ive just used common sense and not used high pressure near any thing that could get damaged. Get a good engine cleaner like stated above, spray it on let it foam up and rinse off. Some areas may require like rickrousch03 said a mit or scrub brush to aid in cleaning.
Use common sense and every thing will be fine with out taking or covering any thing up
Oh and do it on a cold engine
Old Mar 1, 2006 | 10:38 PM
sbuswell's Avatar
I need 2 more gears
definitely cold engine. I am very careful so I always wrap up all plugs and disconnect battery, not a big deal I guess. BTW does anyone know the name of that really good foam cleaner? I can't remember it and it's bugging to shit out of me.
Old Mar 1, 2006 | 11:03 PM
Future JDM Whore
god i love this forum lol thanks fellas maybe ill do it before the summer ill post pics once i get it done
Old Mar 2, 2006 | 08:42 AM
NSXNEXT's Avatar
I've had success removing the engine and placing it my kid's bathtub. I use Johnson and Johnson gentle body wash to get it clean.
Old Mar 2, 2006 | 06:51 PM
Agean Blue Bishes
enginebrite is the one that comes to my mind, thats a foam
Old Mar 2, 2006 | 08:17 PM
fsttyms1's Avatar
Maybe ill have to try that while my engine is out!
Old Mar 5, 2006 | 06:06 PM
ou sig's Avatar
Boomer SOONER
I have cleaned my engine many times and never covered a thing (except my air filter when I had a CAI). Do you think your engine stays dry when you drive in the rain??? not a chance. the best thing is to use a water hose w/o any spray end on it, just regular light hose pressure to rinse everything off and you wont have a problem. I use simple green BTW and it works great.
Old Mar 8, 2006 | 02:59 AM
willieesco420's Avatar
ive been told that tire foam works great.. cold engine obviously and dont spray things that look like they shouldnt be sprayed.. seen the after, looks like a new one..
Old Mar 8, 2006 | 07:36 AM
Phrosttz0's Avatar
at my friends detail shop they just spray degreaser all over the engines, scrub it with a brush, then rinse it down, spray a lil shine on there, and your good, no problems with doing it like this, just dont sit there and flood the wires and plugs and youll be fine
Old Mar 8, 2006 | 09:46 AM
RickRoush03
only thing i hate about all that "dressing" applied to the engine is that while it may look great initally, dirt is attracted even more and clings to that stuff and you just can't rinse it away.
Old Mar 8, 2006 | 10:34 AM
ZeroPSI's Avatar
All your base belong to
Since a majority of the egine is plastic covers, I just spray some tire foam on, turn the engine on for a bit, then wipe down. It usually has pretty good results.
Old Mar 8, 2006 | 10:25 PM
ou sig's Avatar
Boomer SOONER
very true, that is why I dont like using the stuff on the dash and door panels - seems the dirt always sticks more. but it does look nice!
Old Mar 9, 2006 | 08:56 AM
CL Platano's Avatar
Tristate ViP Crew
Yep, that's what I do ..
Old Mar 24, 2006 | 12:56 AM
Topher707's Avatar
05 Acura TL: a-spec
nice, nice... I am going to have to try this, this weekend... mine is sooooo dirty!
Old Mar 24, 2006 | 05:47 AM
PenancE's Avatar
lol
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Thuneau
Oct 3, 2015 04:19 PM
jmaxima03
Sep 27, 2015 10:22 AM
