XSP header issues!
Old Jan 16, 2007 | 05:50 PM
xdxlx's Avatar
XSP header issues!
I have a rattle between 2500 and 2700 rpm ( a nasty one at that ). Any ideas guys?
Old Jan 16, 2007 | 05:51 PM
fsttyms1's Avatar
Who installed it? Did it fit properly? Was any force needed to bolt it up? is the lower hanger still in one piece? Check your heat shields
Old Jan 16, 2007 | 11:12 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
most likely its the heat shield. make sure it is tight. also does it only do it when its cold. or both hot and cold?
Old Jan 16, 2007 | 11:20 PM
Phesto's Avatar
Sounds like something is loose.....follow above posts.
I've had mine for a while now and still no issues.....hopefully you got just a small problem.
Old Jan 16, 2007 | 11:46 PM
Rpappi's Avatar
i have a minor problem but it is either because i removed my resonators or my muffler is bad. the sound only sounds like it is coming from the left tip but it is too loud to tell. when i get my new exhaust in the late summer i will have that fixed. it only does it when it is cold.
Old May 4, 2007 | 09:43 AM
xdxlx's Avatar
so ive been trying to fix the problem, but the noise seems to be coming from somewhere else. It sounds more like air is "slushing" through around that rpm, and theres a loud noise. I dont think my headers are hitting the heat shield. I had it installed at a shop because my bolts were too rusty
Old May 4, 2007 | 10:18 AM
bigdo26's Avatar
02 TL Type-S
Try this - go under the car and disconnect the hanger by the flex pipe. When my XS headers were put on, they resonated / vibrated / rattled very loud around the 2500 RPM range. I discovered it was coming from the whole exhaust system, and when I disconnected the hanger by the flex pipe, the problem was fixed.
I would not recommend leaving the hanger disconnected however, as that puts lots of stress on the headers and can cause the pipes to crack (I learned the hard way). Instead, if the hanger is your problem, have a shop weld a new hanger to a different part of the exhaust piping maybe a little further down from the flex pipe. I had that done as well, and I get minimal resonance now.
Old May 4, 2007 | 10:33 AM
xdxlx's Avatar
thanks for the info, i'll go try it sometime soon. hopefully it will get rid of that problem.
Old May 4, 2007 | 05:38 PM
xdxlx's Avatar
i tried it, but it wasnt causing the sound. i noticed that in the video you have of your car before and after you install sway bars your car sounds a lot deeper than mine does. mine has a cheap sound to it, its disgusting. do you just have xs headers?
Frathora
Sep 28, 2015 11:29 PM
CLsuperhero
Sep 23, 2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
carz0159
Sep 20, 2015 06:11 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
