Xcelerate motor mount install question
What do I do with the vacuum line for the forward motor mount after I install the Xcelerate motor mounts? Cap it, leaving hanging? No time to do forum search, please help.
acrite (07-01-2011)
make sure its airtight seal on the vac hose or a mystery vac leak will haunt you
Or if you want to get rid of the hole system you can remove all the lines from the front and rear mount. then follow it up to the little module that use to control the vacuum and remove that too. it has a two wire plug connecting it. By removing this it will not throw a check engine light. then you have to plug the hole in the back side of the manifold because thats were it use to get the vaccum from. Now you have deleted the hole system.
any links to order these mounts I ordered some off bogus ones off ebay about 8k miles ago and acura telling me they bad already SMH I should sue the other company. Anybody already have Xcelerate mounts? how are they vs Oem factory mounts?
DiamondJoeQuimby
09-10-2015 11:40 AM
