Would this timing tensioner be compatible with the 03 tls
So I'm doing my timing belt and I want to know if this is a good deal. (03tls)
Part numbers are confusing and I'm about 80% certain this will fit. Can you give me confirmation?
Aisin BTH 002 BTH 002 94 Timing Belt Tensioner Honda 14520 P8E A011 M4 | eBay
Made an offer, got him down to $25! Want to be 100 before pulling trigger.
That certainly looks like a part that could fit... BUT I would not gamble on it, specially since it can destroy your engine.
Why are you out-sourcing the parts? the AISIN KIT contains everything OEM and its pretty darn affordable Vs dealership.
Trying to be patient and get all oem parts for under $140. Only 94k miles so a little bit of time to play lets make a deal.
Aisin doesn't make the drive belts or pulleys as that would be Gates from what I've read. Already got a new Yamada water pump for $60 deal searching.
The OEM belt is made by Mitsubosho which is what the AISIN Kit comes with and all the parts with the AISIN kit is what the car comes with from the factory including the water pump which is made by AISIN for Honda.. All that is left is to slap a Honda sticker on all of it and it would be the dealership direct parts.
That is why all the forum recommends the AISIN KIT.. Is the OEM Supplier after-all.
PS: Gates doesn't make the OEM pulleys or drive belts, They make Aftermarket parts for it.
Yamada doesn't make the OEM water-pump. The OEM water-pump is made by AISIN for Honda.
cycdaniel
Dec 17, 2019 10:58 AM
InFaMouSLink
Oct 27, 2015 06:51 PM
