Worn Motor Mount?
Worn Motor Mount?
Hi all. Recently, I brought my 03 TL-S (purchased in 02) in for repair after being involved in a minor accident where the vehicle behind me rear ended me. As a result, my car was brought in to have the bumper replaced. After being in the body shop for about a week. I get a call that my car is just about ready. But the lady that called also stated that the mechanic made a note on my ticket saying my motor mounts were worn (although she didn't say how worn they were). I guess my question is, is this normal given the age of my car ? Please to take into consideration that I have excessive miles on the car (just under 80,000 miles). Is this something I need to worry about and I guess I should assume that this is an expensive repair?
Yes - it's normal for mounts to go out (on every car - not just TLs). When I had my second tranny put in they had to also change out a mount (fortunately - under warranty).
Unfortunately - the hydraulic ones are kind'a expensive.
Yes - the front and rear mounts are vacuum/hydraulic. The part itself runs about $100, and then you have to add labor.
Frankly, I don't know why a body shop is checking your engine mounts while your car is in for a small rear end fender bender. My advise is to say "no thanks" and take it somewhere else.
You know, and I should have mentioned it earlier, that is exactly what I was thinking when I got off the phone with them. All the work on my car was being done to the rear bumper. So, why the hell were they checking out my engine out? Would a bad engine mount be audible, or would you just feel more vibration from the engine? In any case, I told them that I would have Acura check it out for me. I'm thinking it was all
i first heard rattling and i thought it was something with the suspension because i had recently got the springs in...turns out it was the motor mount...the extended warranty does cover it if you have one though
Crap! I, unfortunately, did not purchase the extended warranty
The reason the body shop probably inspected them is because it VERY common for motor mounts to get broken in rear end accidents. It is also VERY common for the TL's front motor mount to go bad. They may not have actually inspected it when it was brought in, that may be why they never said it was bad. (hence brining car to dealer for routine maint usually = waste of money)
Thanks fsttyms1, I assume that you're referring to the Acura folks in the quote above, and you may very well be correct. I guess I was assuming they would have checked that on the last inspection mainly because of the mileage. But checking the motor mounts, like you said, may not have been part of the list. Thanks for the input though
i think its all bullshit. when my TL was in for tranny recall tehy said i needed new motormounts. ive also heard stories were lots and lots of other people were getting the motor mount run around. i think its just a ploy to make some extra cash
41510TL thanks for the input. But let me throw my question out there again because I still haven't received and answer. Is there an audible noise when the motor mount has gone bad, or do you just feel more vibration in the car?
FSTTY HE's right, they may have been broken when you look at them, however eveytime we get a new trans teh motor mounts are bad or need replacing. thats just not seeming logical for US to pay for them ACURA SHOULD PAY and IM going to look in to it
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
Those expenses never seem to end
Thanks bro.
