Won't Start
Old May 1, 2004 | 12:20 PM
Blazin_TL's Avatar
Registered User
Unhappy Won't Start
Been having problems starting for the past two days.. Takes like 2-3 times to start up and somtimes when I start up I put it into gear and it goes back out .... Now today it wont start at all.... What should I do??
Old May 1, 2004 | 12:41 PM
Blazin_TL's Avatar
Registered User
Just got it started.. Had to give it alot of gas though
Old May 1, 2004 | 03:42 PM
`ill*tl's Avatar
Might be a couple things..
.. battery? Check to see if you're electronics are working (eg. Radio)
.. dirty fuel-injectors? Solved by going to your local Autozone, Pepboys, etc. and buying yourself some fuel-injector cleaner (STP, Chevron Techron)
.. '99 TL's had 2 recalls.
Old May 2, 2004 | 02:40 AM
Seotaji's Avatar
fuel pump, battery, or bad gas.
Old May 2, 2004 | 10:26 AM
bbznyc's Avatar
THERE IS RECALL FOR THE INGNITION SWITCH!!!!!!!!! Dealer will fix it free of charge...
Old May 3, 2004 | 12:23 AM
what year is your TL, it might be the fuel preasure regulator. if your car is between 99-01 then that is probably it.
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
