Wiring Question especially for Tein EDFC owners
Just wanted to know where you guys tapped into the cars wiring for the 3 power wires for the EDFC unit. I am probably going to put the unit in my glove box, or maybe in between the seats.
I do alot of work on my cars, but wiring is definitely not my forte
I need to tap into 3 wires;
1. constant power wire ( the yellow EDFC wire)
2. Accessory Power (Red EDFC wire)
3. Illumintaion power supply (Green EDFC wire)
Id appreciate any help you guys can give me. Was wondering if maybe all 3 can be tapped at the fuse box somehow on the passenger side. Thanx in advance, and Happy Thanxgiving guys.
'99 Acura 3.2TL
for the constant power wire you can run a new wire from the battery (fuse it). or i think there's a constant +12v connector at the back of the driver side fuse box.
accessory power: at the back of the driver side fuse box there are 2 empty slots. one is constant, and one is switched (accessory) so you can use the accessory one.
and for the illumination wire you can use the same one as accessory so it lights up when the car is running![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
hope this helps![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
@cUr@-TL
hope this helps
@cUr@-TL
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
cycdaniel
12-17-2019 10:58 AM
alan_rich
09-07-2015 11:08 PM
