Wire harness
Wire harness
Purchased a 1999 TL a couple of weeks ago as a first car for my soon to be 16 yo daughter. Threw a code for the crankshaft position sensor so tore it down to get at it. Problem is the harness connector has been cut off (this I can splice but would rather have the connector). While pulling out the wires several more came with it. Looks like the previous owner taped the wire to the top of the oil pressure switch (no connector) and tried soldering wires to the inside of the connector to the valve timing oil pressure switch (wires cut flush with the connector).
So I'm looking to replace the harness or sub harness for these 3 items and can't find the a description of devices associated with the various harnesses listed online.
I'm also willing to just splice the connectors if they come with a pigtail.
So my questions are:
Can I purchase connectors with pigtails? (Acura dealership only sells the whole harness and won't replace connectors)
What is the part # of the harness(es) for these 3 items? (I assume they are all within the same harness)
Thanks,
Tom
Thanks,
Tom
If your looking for the cheapest way out i would think the Junkyard would be your best bet i could be wrong. As for harness connectors same answer. Also for wiring i know i have used alldata.com in the past. It may assist you if your planning on doing it yourself. Another person who does wiring is rywire.com they may or may not have a harness at a reasonable price.(never dealt with them just heard of them) Good luck hope this helps.
Can you show me pic of the plug ( female connector) that needed pigtail. I have alot pigtail plug that should fit them from my left over wire harness. If your trying find used wire harness make sure its from 99 b/c that only one will work not like other years.
BTW: i'm in Marietta an if your close i can help you out
Okay just found out some more information as far as new clips, if your still checking your thread lol. The site you want to visit is www.newunitedracetech.com They have all the clips you need. But i will warn you better know your $h!t, and more then likely still more expensive then going to junkyard. Good luck
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
09-28-2015 06:51 PM
