window visor install
Old Aug 16, 2010 | 06:55 PM
victorvu's Avatar
hey guys havent been on this side of the forum since my last car but i just picked up another 03 aegean tl-s w/ navi and i got window visors from ebay they're not knock offs it has honda stamped on it and was shipped from japan heres how it looks one of the tabs are broken on the driver side front will this do any harm? Do you know if theres instructions to install it? Also if you look at one of the pictures the wire there was cut do you know what it's wired to that is behind the passenger side fender. TIA
BTW those rims will be off the car and it's dropped on comptech springs.
Old Aug 17, 2010 | 01:40 PM
victorvu's Avatar
all those views but nobody knows?
Old Aug 17, 2010 | 01:44 PM
jjashaa's Avatar
Avant Garde Wheels
dam those visors are in terrible condition.... just clip those tops in and make sure you use new double sided tape. it should hold fine as long as nobody comes and tugs on it hard.
Old Aug 17, 2010 | 01:50 PM
n1njai's Avatar
You gotta roll down your windows and pull down the rubber lining for the windows. I put double sided tape on first, and then inserted the clips and screws into the visors.
Old Aug 17, 2010 | 06:56 PM
01tl4tl's Avatar
Im guessing that loose wire is to the window antenna
Old Aug 17, 2010 | 10:47 PM
victorvu's Avatar
is it the window antenna on the cl side they were saying it was the locking beep. hopefully they will work ill post pics when installed. ill be sanded and reclearing the visors.
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
TxRzrBk
Sep 17, 2015 01:07 PM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
