Window Tint and Navi
I was thinking of tinting my car with 35% all the way around, but I am concerned it might screw up my navi. I thought i remember reading a while back that tint can screw up the navi and mess up the positionl. Any info that can help with my decision will be greatly appreciated. Thanks.
Shogun Assassin
I think it was only metallic tint that had any possible effects...but from what I've read you shouldn't have any problems. I can't speak from experience since navi isn't available in Canada. Hopefully someone with tint and navi will come answer your question.
O.G.
Originally posted by sqamar95
I've had my TL-S for about 4 months now and I got metallic tint and never had any issues with my navi.
I have LLumar PT 28% metallic tint. No problem with Navi. Just make sure the tint guy doesn't cover up the anttena portion in the rear glass, and you shouldn't have any problems with the Navi.
I seriously doubt any tinting can do cause problem for Navi (GPS). I happen to have pocket pc gps with anteanna kept inside storage bin between front seats. It never had problem with signals on neither my Accord or G35. (Accord tinted 35/5 titinum, G35 tinted 15 titinum) Since your anteanna is located at windows, I can see how it can cause problem.
I would stay away from any Metallic tints.
Although some say there are no problems, why take a chance?
Not to mention REAR RADAR detection is reduced too.
Somewhere on the V1 website I remember Mike Valentine talking about it.
I think it is tint BRAND specific. Some are worse then others, but they all reduce signal somewhat.
I’m scheduled for my tint job in two weeks and I’m going with NON-metallic like I had on my last CL.
Shawn S
Shawn S
I've had 35% non-metallic all around for about a year now and have had absolutely no problems. The guy who did my tint said he typically stays away from metallic films unless the customer insists on it. Navi interference along with radio reception problems on cars that have the antenna printed on the glass (TL is one of those cars) is the primary reason he shys away.
1 Post
Okay just got back from getting the car windows retinted.
I had posted a couple of times that I had to take my 51% tint off the side windows to pass Washington D.C. Inspection. D.C. has stupid laws when it comes to tint. You can only have 70% on the side windows & 50% on the rear glass. SUVs & Minivans can have factory tint except drivers & passenger front windows. I had got the TL tinted 2yrs ago when it was new. This was my first time to go to inspection with this car. I had the sides retinted this mourning. They do not use Metallic Tint at that shop. The windows were done the 1st time with 51% Madico Tint & he gave my the life time warranty. This time they put Johnson window films
on the sides & I got 45%. I had a talk with the guy that owns the Ziebart were I got the tint done. Since I had the TL done there before 2yrs ago & also had my 94 ACCORD done when it was new.
He said he gave the lifetime warranty but others most likely would not. He said he used Metallic tint a few years ago but quit.
He said most good tinters do great on the side windows with metallic tint. Its the back window were you have problems.
I asked him how good was the dyed vs Metallic he said its very good. He said it also depends on the manufacture. He said mine should last 6yrs with no effects. I ofcourse have to take the sides off again in 2yrs. The rear will stay on if I have this car I also had the tint on my ACCORD rear window for 6yrs & it should no signs of fading. He said before that smoking does effect the tint & I don't smoke. www.johnsonwindowfilms.com
Posted before, but here it goes again:
I've got 35% Madico metallic graphite tint on my car. It does affect the NAVI, but it still works.
Before I had the tint, using the "secret" navi menu, I had 5 satellites when I turned the car on, and it would find the other 3 withing 30 seconds tops.
With the tint, I have 2-3 satellites when I turn the car on, but it finds the other ones, usually all 8 still, but it takes a little longer, maybe 60-90 seconds. I will drop down to the yellow bars a little more often than when I had no tint.
Despite not having the satellites immediately, our cars "remember" our last position, and the gyroscope does a pretty good job of keeping track of where we go.
One thing you can try is to have your tinter lay a piece of tint across the driver side of your rear window (that's where your GPS antenna is) and see how much that particular brand/metallic level affects your navi. That's what I did and my tinter had absolutely no problem with doing it.
I just got my windows tinted with Formula One all metal film, no dye. The darkness is 18% and I had it done on the front and back sides and rear window.
I have no problems with the GPS.
If you live in the Orlando Area check out Flying Window Tinting in Longwood on 17-92.
Something about getting your windows tinted....it just feels like a different car!
navi and tinting
Manus, I thought of this too before having mine done and an email from American Honda said don't do metallic tint. I told the tint place and he said no problem, we'll use metal type on the sides and non-metallic on the back light. The metallic type is for better heat reflection qualities and doesn't change the asthetics of the tint. I had it done 2 years ago and see no difference in the navi or radio signal. Hope that this helps you. QR
This talk is all a non issue. Metalic tint and the Navi not working is all hearsay. Get the metalic tint and be happy...it will work and I standing proof that it works.
Unless you hear from someone else with TL that put on metalic tint and the Navi got messed up. And then you need to ask them the brand that they used and don't use that. I used Formula One 100% metalic and it works.
I don't understand posters to this thread that comment on having gotten non-metalic tint and their Navi works....duh!
PS - I covered my back window in aluminum foil before I got my metalic tint done and the navi worked. Although it wasn't a conclusive test, I was mearly just experimenting.
Liquid Ice
I have Formula One Ultimate (metallic) tint as well and have no problems with the navi.
