will my Vafc reset if...
@ slide or die @
I need to remove the battery and do some electric work which will last much over 15min and i know the ecu is going to reset (whopty f**** do right). Question is, will the Vafc reset its settings from having no power 'cause i dont want to have to pay another $130 to get the car re-dynotuned.
helps appreciated. ty!
*btw i changed the batter not long ago and the vafc didnt reset, but the car must've been out of power for like 2minutes.
Received 1,080 Likes
1st gen VAFC saves all the settings. Think about it. when you shut off the engine, there is no power to it. Unhooking the battery doesn't do anything different.
@ slide or die @
![Explode](https://acurazine.com/forums/images/smilies/explode.gif)
anyone 100% perfectly absolutely positively and utterly sure?
Originally Posted by etxxz
sounds like you have a doubt there.... seems like i'll have to write down all the settings and reprogram them IF it resets...but then there's a lot of menus and i might miss something =
IF the vafc only has 1 power wire cutting the power wont reset any thing. like nsxnext said, it would be just like turning the car off over night
Dragging knees in
@ slide or die @
^^sure what would you like to see
fttym, i can't exactly tell which of the 300wire coming in/out of the vafc and ecu is a power but i do understand what you mean if it only had 1.
i'm calling apexi!!
i'm calling apexi!!
