Will a body shop.....
Will a bodyshop install side markers? And if so, how much would it cost just for them to drill/dremel the hole? And how long do you think it'd take?
I'm looking to install some Aspec or BMW side markers, but I'm wayyy too afraid to take a dremel to my fenders. I can do the wiring myself, but man.. fear of an unsteady hand makes me willing to shell out a hundred dollars to not risk messing up a fender.
I get all my work done through a friend of mine who owns a body shop and he charged me $25 for both sidemarkers on my previous car...which is dirt cheap. He normally charges about $50 for both & it takes him about an hour.
i feel the same way. i want to get side markers but dont know which ones to get. and would it be better to do yourself or do it at the shop? hmm which ones would people prefer to get for side markers
hey do you have any pics of some good looking sidemarkers installed on the 2nd gens. I've been wanting to get them also but can't figure out which ones to go with. The 3rd gen TL sidemarkers are too tiny and don't flow with the 2nd gen tl.
7-series on my TL
My ass. The paint does not peel, and yeah I can see why they might scratch the area. Dremeling is a tedious process: one wrong slip of the hand and you have a scratch so deep in your paint that you can see the silver of the metal in your fender. Luckily for me, I scratched inside the cut out area, so I was ok.
I would suggest also having a touch up paint pen to paint the edges where you cut out the side markers. I haven't yet put on the clear coat for that part yet, but I'll do that in a week or so. Been too lazy to work on the car for the past few days.
For those that want it professionally done, the cheapest qoute I got was $175 per side marker. And that wasn't without wiring. That was just for punching/drilling/dremeling the holes. The most expensive I got was $265 per side marker.
difficulty and time? does it take long and how long will it take. is there a diy on this site on installing side markers. they look sick!
As for difficulty, I say anyone with a steady hand and balls could do this mod fairly easily. I used Dark Shear's DIY for the dremeling part, but I had to get my own measurements.
Here's a tip: Get a sheet of plastic to pre dremel a cut out. I got old tupperware, and measured out the holes to see how if it would fit. I would then fit my side markers onto the tupperware with the hole and see if the side marker would fit correctly. After I got the perfect cut out, I used it as a stencil to put on my fender for the cut out. After that, it's fairly easy.
Also, Dark Shear's DIY suggests that you jack up your car and get underneath the splash guards. I didn't want to take off my splash guards because with the OEM lip kit on my 03 TL-S, it meant having to take of the front Lip off. So here's what I suggest. If you look in your owners manual, in the back they'll tell you how to replace turn signals and indicator lights. All you have to do is:
1. Jack up the car so that you have enough clearance to fit your arm in the fender well. If your car is lowered, you will need to give yourself about 4-6 inches between the tire and the fender to stick your arm in. I don't know how big the average person is.. but if your forearms are thicker than 6 inches.. then yeah, just follow Darkshear's advice of opening up the splash guard under the bumper.
2. Take off 3 plastic tabs/gromets so you can pull back the fender well splash guards.
3. Stick your hand in and rotate the turn signal bulb and pop it out.
4. Do the same for the indicator light, which is located right below the turn signal bulb.
5. You can now pull both of them outside the fender well, just enough to replace the bulbs.
6. Get an exacto knife and cut the electrical tape that encapsulates the wires.
7. Using Dark Shear's DIY, use tap in connectors to the correct wires to get the desired function. (Black + Green = turn signal operation for the side markers) (Black + Red = stays on all the time when you turn on your head lights like your indicator bulbs)
8. Replace the plastic tabs/gromets and voila, you now have turn signals.
Actually... I'll post a DIY for the 330 side markers in a few days. I guess explanations with words is just too hard.
Originally Posted by tits legendary
Sounds like a lot of work for something that doesn't even look that cool.
Yesterday, 1:46 PM
tits legendary vbmenu_register("postmenu_1620284", true);
Goon!<---------------------- I think this explains the comment just fine
Post #14
Post #14
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
