wierd headlight problem
Old Feb 11, 2005 | 10:58 PM
Blazin_TL's Avatar
Registered User
ok like 3 months ago i was in the gas station and i was pumping my gas and the guy infront of me was like you know one of your headlights are out and im like wtf.. so i look and yup its out. So i finish at the pump and pull out all pissed off so at the next light i say hey lemme turn the lights off and turn them back on and viola there back on.. so no problems in the past three months.. now tonight im at a light and i see the reflection from the car infront of me that my light is out again (same light) so i do the same thing.. on and off.. and it works. why is my light doing this? its bothering the shit out of me bc i dont feel like changing my lights.. so whats goin on here?
btw: my headlights are cleared but never had any fogging... if that matters?
Old Feb 12, 2005 | 10:04 AM
Blazin_TL's Avatar
Registered User
bump
Old Feb 12, 2005 | 10:05 AM
disgookonfiya's Avatar
i had a similar problem yesterday, i was driving, and used my highbeams, and then my headlights went out, i turned it off and back on while driving and it worked again, first time it ever happened...
Old Feb 12, 2005 | 11:09 AM
alleyesonmeee's Avatar
MIA
I had that problem when I first got my car, it ended up being a cracked headlight housing with water leaking into the ballast. Bring it to the dealership.
Old Feb 12, 2005 | 11:18 AM
Pure Adrenaline's Avatar
Dragging knees in
My HID foglight does that once in a while on the passenger side. There's no leak or anything, so I don't know what it could be, besides possibly some kind of an electric problem.
Old Feb 12, 2005 | 11:23 AM
Bxscig's Avatar
Are the keys in the ignition? If they are then probably a faulty relay or connection some where.
Old Feb 12, 2005 | 02:15 PM
MikeTL-S's Avatar
Not for anything, but check the fuses under the hood
Old Feb 12, 2005 | 02:19 PM
Blazin_TL's Avatar
Registered User
yeah but don't u think if a fuse was blown the light wouldnt work at all?
Old Feb 12, 2005 | 02:21 PM
MikeTL-S's Avatar
no- mine did did the same thing, flickered sometimes then eventually yes, it went out completely. It turned out to only be a fuse. Check under the hood, it will take 5 seconds.
Old Feb 12, 2005 | 02:22 PM
MikeTL-S's Avatar
there are separate fuses for the left and right side headlights
Old Feb 12, 2005 | 02:51 PM
Skert_Newb's Avatar
Weird Headlight problem
Yo, My 2000 has the same problem. i talked to a couple of automative electricians in my area, and they said that my ballast is acting up. So I went to the dealership and they said that a Ballast Job will cost me at least $375.00. That's what they told me, they might give you a different quote. oh, and I tried switching the fuses around because the horn relay & both headlights use the same kind of fuses. I think one of my ballast wires is loose or exposed in some manner. If I could get to it I'd fix the shit.
tman570
Jun 11, 2019 07:56 AM
TLrascal
Aug 3, 2018 11:00 PM
MistaWet
Sep 15, 2015 08:26 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
