Why cant we turbo our cars | 2003 Acura TL Type S |
whitetiger5 (04-16-2021)
It would be easier and more cost effective to supercharge ones current TL. Granted your tranny will handle it.
LevelTen.com can build your tranny from 500whp-1000whp.
Acura TL Builder (04-16-2021)
perhaps you read this in an old thread. Where guys used to put 8psi HBP(High Boost Pulleys) on and then had belt slip.
I used to hella use meth(the ethanol you sickos) and my Comptech charge would cool down to 78-88F on a 90F day.
Now the AEM injection system will be repurposed for spraying alcohol onto my intercooler to cool the air-to-air turbo charge.
justnspace (04-16-2021)
There is no Comptech M90.
Comptech uses the Magnuson brand MP62(62CFM) units only.
Eaton uses the M instead of MP. So an “M90” is an Eaton 90CFM unit.
Unless you custom fitted an Eaton M90 onto a Comptech snout?
I have the last Comptech snout as a spare and an Magnuson MP90 S/C I will fit onto it to make an “Comptech” MP90 unit.
Do you have a 62cfm or a 90 CFM unit?
If you have a 62cfm with both of those pulleys on a 4 rib then your running well north of 10psi on an MP62. So of course your shredding belts. Try only a HBP on man mp62 with belt spray and you’ll be fine.
Unregistered Member
I have a Comptech unit with a Magnuson MP90 fitted on. It bolts directly to the shaft, but you will need to modify the charge outlet, and make an adapter plate for the inlet.
I have a 3.6L engine, so the 62cfm unit with stock pulleys makes less than 3 psi. With the high boost alternator pulley and the high boost SCer shaft pulley, it made about 5psi with slippage. The MP62 is operating at the limit of it's efficiency with the 3.2L, so it's a poor choice for a 3.6L engine.
Nah, I'm running a 90cfm with a high boost alternator pulley and a high boost SCer shaft pulley. It WOULD make a shit ton of boost, but there's just no way the 4 rib can keep up. There's no solution without getting a custom alternator pulley, or converting to a 3G TL style SCer. I'm just planning to go turbo at this point.
Acura TL Builder (04-17-2021)
I like your build man! How many people do you know of with 2G MP90 Comptech S/Cs??
I know of only one guy "Chito Simmons" with a 3G M90 and hes been dreaming to install it for 3.5 years. Ive tried to buy it off him for a long time and hes got a death grip on it. Cant wait till he installs it, will be a fun unit.
Cbble (05-13-2021)
F-C
Motorsports News
23
04-29-2021 09:15 PM
Zalami3196
04-06-2017 09:02 PM
