Where to get stock NSX/S2000 wheels from ?
I already posted this in an earlier topic but no response yet...so posting once again.... basically where to get NSX front wheels or S2000 rear wheels - both of which should fit in the TL I guess ?!! Also, approximate costs..
2000 Naples Gold 3.2TL/Navi - Factory Stock but with up-graded tires
Jeff
Legendary94GS Auto
Razo shift and pedals
RM Racing Intake
Greddy Trust Exhaust
17" Chrome Momo Arrows
Ground Control Coilovers
JDM One-Piece Headlights
OEM Foglight Kit
Originally posted by 94LEGENDGS:
Unfortunately the only place I know of is http://www.aaarims.com and expect to pay $450 per rim for the NSX's. Are you looking for the Zanardi edition rims. they list the s2000 rims at $225 per rim and you should use the fronts that are 16x6.5. It is my understanding that the NSX has a larger stock hub than the TL like the Legend has.
Also, could someone post the Offsets of the following wheels:
a) S2000 front (16 x 6.5) and rear (16 x 7.5)
b) NSX front(16 x 7) and rear (17 x 7.5)
c) Stock 3.2TL rims.
Thanks in advance.
Thanks in advance.
since noone is responding the quickest way to find out might be to call one of those large tire/wheel store chains like America's Tire or Discount TIre Direct, Tirerack.com they usually have information like that
Jeff
Legendary94GS Auto
RM Racing Intake
OEM Foglight Kit
Jeff
Legendary94GS Auto
RM Racing Intake
OEM Foglight Kit
Guys,
I did some searching and got the info I wanted from the following site:
http://www.nsxprime.com/FAQ/TireWheel/wheeltech.htm
Here are excerpts about the NSX wheel specs from the above site:
What Are The OEM Wheel Specs?
Sizes
1991-1993 Front: 15" x 6.5"
1991-1993 Rear: 16" x 8"
1994-Present Front: 16" x 7"
1994-Present Rear: 17" x 8.5"
Lug Nut Torque Spec
The torque spec for the factory lug nuts is 110 N.m (80 lb-ft) for all years.
Factory Offsets
The NSX's front offset is 55mm and the rear is 60mm for both the 15"/16" and 16"/17"
wheel sizes.
The NSX's front wheels fit the 97 Preludes (and 3.2 TL's) in either 15 or 16 sizes. Lock your wheels!
Center Bore
The NSX's proper centerbore is 70(.1)mm front, 64(.1)mm rear.
Factory Bolt Pattern
The NSX has a 5-bolt pattern with a 114.3mm bolt circle.
Lug Nuts
OEM wheels use a 19 mm lug nut. Thread pitch of 12 mm x 1.50
Hope this helps.
Sizes
Lug Nut Torque Spec
Factory Offsets
wheel sizes.
Center Bore
Lug Nuts
Hope this helps.
So here is a summarization of the previous posts about the offsets:
1) S2000 (offsets and weights)
Front (16 x 6.5) - 55mm - Cast Alloy
Weight - 17.8lbs
Rear (16 x 7.5) - 65mm - Cast Alloy
Weight - 18.8lbs
2) NSX (offsets and weights)
Front (16 x 7) - 55mm - Forged Alloy
Weight: 16.75lbs
Rear (17 x 7.5) - 60mm - Forged Alloy
Weight: 20.85lbs
3) Stock 3.2TL rims (Front and rear are same)
Front (16 x 6) - 55mm - Cast Alloy
Rear (16 x 6) - 55mm - Cast Alloy
Weight (25 lbs ??)
Now a question:
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by hunter001 on December 09, 2000 @ ]</font>
Weight - 17.8lbs
Weight - 18.8lbs
Weight: 16.75lbs
Weight: 20.85lbs
Weight (25 lbs ??)
Now a question:
I had posted my questions in the below NSX forum, and here is the link and their answers:
http://www.nsxprime.com/ubb/Forum1/HTML/000990.html
Still awaiting some more info from them.
mtl_ilx
Sep 3, 2015 09:58 PM
