What's the best scratch remover?
Guest
Posts: n/a
I found out my friend's cat had been climbing up my car and causing these little scratches on my car. None of the scratches are deep and looks like a good scratch remover will get rid of most of it. Can you guys tell me what are the best scratch removers? I'm real skeptic about scratch removers because I've heard a lot of scratch removers remove more than just scratches, like your paint. Please give me your input.
I heard zaino the best out right now... they've talked
about in numerous times on this board and also
on the lexus board....
one of the zaino products is specifically for scratch removal...
i may try it this weekend... so if it works i'll post it here...
Originally posted by NSXNEXT
3M Perfect It
3M Perfect It
I've alway used 3M Finessett. It's for minor scratches. Works great.
Not a Blowhole
I assume you mean Hand-applied?
Orbital buffers do a far better job, and the polishing compounds designed for orbital use also are superior.
If you are serious about getting this corrected, go to a skilled professional.
I use a Porter Cable random orbital with Griot's polishing compunds that are designed to work in the low heat. Even with this, there have been scratches that I had to go to a pro for.
I used this crappy scrach remover from Turtle wax which only costed me 2.96+tax but guess what happen, not only it couldn't remove the scrach but creat many many more fine swirl marks and I think it also took out the clear coat becauase no matter what I did (waxed and polished) the area now looks very dull. What should I do now?
-A
-A
Originally posted by oracion
How does that work? If the scratch is into the paint, do I need to apply a layer of touch-up paint?
honestly.i do not believe there is any good scratch remover in the markets.if u want the scratch remove completly,a new paint job is a good idea or even a touch up paint is better than scratch remover..
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
