whats the 5 and the 30 in 5w30
I am about to change my oil with mobile 1 and was wondering what the 5 and the 30 is in the 5w30 and whats that best to use during winter under normal driving conditions (10w30, 10w20, 10w30, 5w30, 0w30). Does one get better gas mileage than others?
Just stick with 5W30 for all year round use. It will protect you enough even in the harshest time in winter, and provides excellent protection in warm weather. The best part is you only need to change your oil once every 8-10k miles.
Enjoy!!!
Later...
Enjoy!!!
Later...
Dragging knees in
The first number indicates the viscosity of the oil in cold weather. The colder the weather, the lower the number should be. The second number indicates the viscosity of the oil at operating temperature.
Honda recommends 5w20 in our cars. But Mobil1 doesn't make 5w20 synthetic. So I use 10w30 in the summer and 5w30 in the winter, changed every 3000 miles.
The first number of a multigrade oil (ie 10W-30) stands for the viscous weight the oil is at when the car is started and the oil is unheated. The W means winter (signifying that the oil is cold). As oil warms up it becomes more viscous and that is where the second number comes up. So when a car is using 10W-30, the oil is weight 10 at startup and once the car is fully warm the oil weight has a viscosity of 30. You shouldnt notice a huge difference in mileage with any multigrade oil.
I would change the oil every 7500 if your using synthetic oil.
http://auto.howstuffworks.com/question164.htm
Originally Posted by fsttyms1
not all. the 99-2000 were 5w30. just stick with 5w30 its a great all around weight. if in the summer you do alot of stop and go and lots of ideling jump up to a 10w30 in summer only
The change to 5w-20 was just to increase Honda's overall cafe MPG numbers which is important especially with the popularity of their SUV's. I ran 5w-30 in my car as well.
Ackniculous One
Quote per website: "Mobil 1 with SuperSyn 0W20 is engineered specifically for Ford, Honda and any other vehicle where a 0W-20 or 5W-20 engine oil is recommended"
http://www.mobil.com/USA-English/Lub...bil1_0W-20.asp
http://www.mobil1.com/tools/which/ge...=2025&x=38&y=6
Dragging knees in
Originally Posted by CJITTY
Not quite 100% true. Mobil 1 does make a synthetic oil designed for our cars. I've been using it for about a year now. It's Mobil 1 Synthetic 0W-20 (grey label). I got it at Checker's and also at Wal-Mart. If you go to the Mobil 1 website, it says it's specifically made for Ford and Honda automobiles that require the use of 5W-20 conventional weight oil. Check out the two sites for more info on this
See, my whole thing is, if it's "like" 5w20, then why don't they call it 5w20? That's why I don't consider it as 5w20, although it is designed for it.
fstty -- I'm biased. When I say "our" cars, I mean '02-'03 TL-S.
Found this while reading. I don't know how useful this will be, but some aspects are worth reading (You just have to get past the marketing fluff in the beginning). Enjoy:
http://motor-oil-bible.com/mob-2-2-04.pdf
Dragging knees in
the only reason honda went to that oil was to try to improve gas mileage and meet/or stay below cafe standards. there is no harm in 5w30. i personally dont llike the idea of something so lo in weight 0w20-5w20, but for most normal drivers (NOT ME ) it would be ok
yea...but how often do you guys change your oils if you are using synthetic? I change it every 4-5k..but you guys saying its good till 7500?? I know its better to change it often..but just wondering.
yea...I use Mobil 1 5w30 for summer n 10w30 for summer..but how often do you guys change your oils if you are using synthetic? I change it every 4-5k..but you guys saying its good till 7500?? I know its better to change it often..but just wondering.
yea...I use Mobil 1 5w30 for winter n 10w30 for summer..but how often do you guys change your oils if you are using synthetic? I change it every 4-5k..but you guys saying its good till 7500?? I know its better to change it often..but just wondering.
