What Time is it?
Old Sep 2, 2003 | 06:04 PM
Vffr1's Avatar
Team Anthracite President
What Time is it?
I noticed that on my 2003 TL the digital clock doesn’t light up when I turn the lights on.
I don't ever remember there being a light there, can anyone confirm if the clock should be lit?
Thanks,
Mike Smeezy
35% Full Tint
Front Nose Bra
17” Type-S Rims
Rear Deck Spoiler
H&R Sport Springs
Anthracite 2003 TL
Old Sep 2, 2003 | 06:31 PM
Tatewaki's Avatar
Clock is lit. You prob got a burnt bulb
Old Sep 2, 2003 | 08:55 PM
My 99 did that once. I got kind of p*ssed off and smacked the dash over top of the clock two or three times. It magically came back on, and in 3+ years since then it has not gone back out. Don't know if it was the clock, a bad connection, or if it is simply scared of me. . .
Old Sep 2, 2003 | 09:24 PM
magicman8888's Avatar
My clock did the same thing. I just tapped it a couple of times and it came back on.
Old Sep 3, 2003 | 12:12 AM
TypeSDragon's Avatar
Loving my 08 TLS!
Thumbs down
Do you need to take out the dash in order to change the bulb? I tried tapping on mine, but it is not lighting up.
Old Sep 3, 2003 | 05:47 AM
3rd Gear
Had the same problem, took it to the dealership, when I got the car back i had a rattle in the dash, found out the bozos broke a fastening piece inside the frame that the dash attaches to. After months expermenting,I had to put a screw in the dash to stop the ratlle. If you want my advice, live with it
Old Sep 3, 2003 | 05:57 AM
acur8's Avatar
The dash must be removed. if you're handy, you might be able to
'loosen it' (i.e. remove it but not take it completely away from the steering column which is a pain to get around) and use a small screwdriver to remove and replace the bulb from behind (it'll be right behind the clock). Careful - there's a lot of wires connected so don't just yank out the dash. See the frequently asked questions on this site under replacing gauges for instructions on how to remove the dash. I believe it's question #8.
Old Sep 4, 2003 | 06:59 PM
Vffr1's Avatar
Pretty impressive response, thanks folks!
Michael
35% Full Tint
Front Nose Bra
17” Type-S Rims
Rear Deck Spoiler
H&R Sport Springs
Anthracite 2003 TL
Old Sep 4, 2003 | 08:02 PM
bigmonkey70's Avatar
No, you don't have to take the whole DASHBOARD out. Just have to takeout or loosen the dashboard lower cover (instrument panel) out. There are 2 screws on top. Then gently pull out along the bottom to release 6 clips, then along the top to release the remaining 3 clips. Disconnect the TSC/CC/Moonroof connector and reset/select/hazard then disconnect the clock and climate control connectors. You might be able to pul out the dash a little (without remove it entirely) to have access to the bulb.
Old Sep 4, 2003 | 08:07 PM
Ooops ... Hit refresh button = double post
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Skirmich
Sep 15, 2015 06:41 PM
forrie
Sep 15, 2015 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
ShyGuyMcFly83
ILX
Sep 11, 2015 10:51 PM
