What exactly are the symptoms of warped rotors?
My friend mentioned that we wonder if my rotors are a little warped because once in a while, when I'll stop from 40+ the car feels like it's buckin' a lil. Almost like it's on a lil bumpy road. The steering wheel is perfectly smooth while braking, always.
I have another friend who whenever she hits the brakes on her her entire steering wheel shakes violently. And you can feel the car bucking a lil bit too. It's real obvious her rotors are messed up.
How can I tell if my rotors are warped? Do warped rotors show their signs at all speeds? Is it possible they'll only occasionally show theres warpage when stopping from higher speeds?
Thanks in advance,
Noam
Thanks in advance,
Noam
OG
Usually, you can tell when your rotors are warped is when the rotors are "hot". Meaning that you either are doing repeated stops in a very short periods of time, braking downhill or high speed braking. When your rotors are warped, you will feel pulses on your break pedal and depends on how severe it is, your steering wheel might shake too.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. PIAA yellow plasma ion fog bulbs. More to come later......
My AcuraTL Homepage
How do I have a dealer check them for me then? They have to heat them up first? I don't want to embarrass myself and have them check my rotors to find out they're not really warped, ya know?
Noam
Noam
OG
They can check them. They will take different measurements at different points on the brake disc. If the measurements are off, then they'll either have to resurface the rotors or replace them. If you are experiencing rotors warpage, then bring it back to the dealer and let me check it.
Thanks for all your help! This is probably a record # of back and forth posts in a given time.. I appreciate all your info. I just don't want to feel stupid if they're really not warped, because they usually feel fine to me.. it's once in a while I get that lil feeling that they might be, and it is usually when it's hot, so you've helped a lot. I heard warped rotors were a problem with these cars too. I wonder if Park Ave Acura will just replace them for me? We shall see. Thanks again for all your help.
Noam
Noam
Noam
Noam
However, I've begun to notice a pulsing feeling during several normal red-light stops. But I can't tell if it is my brake rotors or if there are ripples on the road surface (from cars braking over the same spot over and over). I did try braking on random stretches of road several times and I haven't sensed the pulsing feeling yet.
How severe is the pulsing feeling? I guess it varies depending on how warped your rotors are. Maybe I'll have the dealer look at it the next time I get my tires rotated.
In plain English, your steering wheel will shake like a mo-fo when you brake from speeds anywhere from 40+ mph. That's when your rotors are warped.
Ed
Acura-TL.com - Forum Moderator
'66 Mustang Fastback
'99 Mazda Miata
'99 Acura TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
'99 Mazda Miata
Pics of my TL
This is a common problem in TLs, and is quite annoying. I had Acura turn mine at 14k miles.
try hitting the brakes at speed, and see if the steering wheel does the characteristic left-to-right jiggle when braking. If so you've got warped rotors. I've never had this happen at such low mileage, and suspect that Acura cut corners on the rotors and they're too thin for the job.
'01 White Diamond Pearl 3.2TL
-Wing, tint, wood and Whistler
I have 35,000 miles and my rotors are about as warped as they can get. My steering wheel shakes like a MOFO when braking. I brought it to the dealer and they said it's a wear and tear item and also they warped because maybe they over-torqued the lugs when I put on the aftermarket rims. Bunch of BS, my rotors were warped before I had my C-5's.
RWD convert
I have the symptoms of warped rotors as well. I only have like 14k miles on my TL.
Y2K SaTiN SiLvEr BoTTleFeD 3.2TL
-AEM Short Ram intake
-AEM Tru-power pulleys
-NOS 70 shot wet Nitrous System
-Magnaflow exhaust
-Ground Control coil overs
-BLITZ 1.3 kg radiator cap
-Factory underbody kit and Wing
-Mesh grill
-Body color door handles
-20%/35% Llumar Platinum tint
-Räzo Shifter
-2 Rockford 10" XLC subs/Boss Audio CLR60 amp
-Magnaflow exhaust
-Mesh grill
-Räzo Shifter
The dealer saying that it's wear and tear is b.s. I just brought my 2000TL with 24K miles to the dealer and complained about the steering wheel shaking during high speed braking. They replaced the front rotors and the front pads. They said the rear brakes were not warped at all. I didn't even have to argue with them about fixing the problem. If you're dealer won't fix it for you, find another Acura dealer. The original rotors\pads are crap, and Acura knows it and they should fix it for you. Good Luck!
if u only feel shaking/bucking and/or pedal feedback , it's possible that it's your rear rotors. when your fronts are warped, you'll feel it in the steering wheel (i warped 2 sets of fronts )
-Fiddler
ControlGenie Automation Systems
1998 Accord EX V6 Coupe (HomePage)
-Fiddler
Acura/Honda has built cars for years with very sensitive brake systems. The rotors are very prone to warping.
You'll notice warped rotors most when slowing at high speed. You'll feel like your about to rattle your teeth out.
If you are doing them yourself, I prefer factory pads and rotors (if replacing). The materials used in the aftermarket are sometimes inconsistent or incompatable with the factory stuff. My Legend was always happier with the factory parts than when I tried to save a few $$.
I've been lucky so far on my TL. At 45k miles, mine are still fine. But, I have had Honda Acura rotors warp on almost every car I've had at some point, so I've just dealt with it. If its happening at 15 or 20k, the dealer should be checking it out for you.
One note- dont wash your wheels while the rotors are hot, that ads to the warping prob. I always wash my car after the car has been sitting for awhile so the brakes are cooled down. the sudden cooling that water causes will warp the rotors quicker.
SidhuSaaB
05-30-2020 12:40 AM
us285126
10-02-2015 02:03 PM
