What Is The Center Dashboard Knockout?
Old Nov 22, 2006 | 03:44 PM
MikeekiM's Avatar
There's a little knockout panel in the center near the base of the windshield...
What is it? I thought it was just a simple knockout panel...but when I yanked it, there's a wire harness attached to it...
This is a source of noise for me...the center panel rubs against the dashboard and created a lot of squeaking... I yanked it to spray a little silicon spray to hopefullly quiet it down...
Old Nov 23, 2006 | 10:37 AM
acurabum's Avatar
No no no ..It's a sun temp sensor for your auto climate control ... you might want to
clean it before your Auto climate control goes crazy ...
Old Nov 23, 2006 | 11:03 AM
MikeekiM's Avatar
I just sprayed the outside with silicone spray... Didn't touch the connectors... I am pretty sure I didn't cause anything that would make the sensor any less/more sensitive... But I will check just in case...
It was making a lot of noise...when the car hit little ripples in the road, the edges of the sensor chaffed against the dash that it is in contact with...so I had to do something to get rid of the noise...
Weird place to place a temp sensor... Usually, you place a temp sensor out of direct sunlight... Instead, Acura places it in one of the hottest areas?
Old Nov 23, 2006 | 01:03 PM
acurabum's Avatar
There are 3 of them in our car ...one in front of the radiator ... two just underneath the ignition key ( little fender ) ..... and free the SUN SENSOR that you did spray ....
third sensor is there 'cause it's a SUN sensor ....
Old Nov 24, 2006 | 08:06 AM
fla-tls's Avatar
On the way!
Yeah - it's job is to measure sunlight. You'll notice sometimes that when you go from a shadowy place in thew summer and drive out to where sunlight is directly hitting the sensor - your blower fan will speed up?
That's the sensor doing its job.
As far as I know - there's only one more sensor (a temperature sensor), and it's the little grill-like cover on the dash near your right knee. It's actually hooked to a vacuum line that goes to the fan intake, so the stronger the fan blows - the more air goes over the sensor.
acurabum - where's that 3rd sensor and what's it there for?
Old Nov 24, 2006 | 09:55 AM
acurabum's Avatar
The 3rd one is an outside temp sensor and it's located and cliped to the front grill
just in front of your radiator ..
Old May 13, 2007 | 02:51 PM
farmdevil's Avatar
She thinks my TL's sexy.
I bought my car from a friend last year. While he owned it, the cap on the sunlight sensor popped off. He lost the cap sometime after that. I think it looks bad to have that hole up there and also I suspect the cap being gone is making my A/C be a bit sporadic.
The dealership wants more than $40 to buy a whole new sensor. Does anybody know anything about finding just that cap without the actual sensor?
Old May 13, 2007 | 07:45 PM
fsttyms1's Avatar
Junk yard
Old Jul 26, 2007 | 12:23 PM
farmdevil's Avatar
Apparently junk yards don't inventory that part. I found a yard that thinks they have it but they want a picture. Does anybody have a pic of a sunlight sensor?
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
