Went to the Track today
Old Jul 27, 2007 | 10:26 PM
ac5320's Avatar
The Brown dit
went to the track for the first time today...stock TL Type-S here are my two best times.
1) R/T-.240, 60-2.463, 330-6.694, 1/8-10.085, mph-72.28, 1000-13.019, 1/4-15.487, mph-91.63
Got my ass kicked by a SRT-8 that ran a 12.7
2)R/T-.421, 60-2.455, 330-6.669, 1/8-10.050, mph-71.39, 1000-12.971, 1/4-15.439, mph-91.88
This time i got my ass kicked by a mote carlo running a 9.8 or so
I got the headers and intake in my garage, havent put them in yet...car was complete stock. Both times i had the vsa shutoff, with the vsa on my times were 15.5 and 15.7
Old Jul 27, 2007 | 10:46 PM
FL3.2TL's Avatar
Just chillen..
Dude, 15.4, that's slow for a Type S, you should be in Mid 14's
Old Jul 27, 2007 | 10:51 PM
02type-s's Avatar
-Arsenic-
ac5320's Avatar
The Brown dit
hey man never said i was good at it. didnt take out spare and spun a little bit..are you sure i should be running mid 14's stock? i think that might be to fast isnt it?
Old Jul 27, 2007 | 10:56 PM
FL3.2TL's Avatar
Just chillen..
Nope, a Tl-P does about 15.0-15.3, and a Type S has 260 HP compared to the TL-P which only has 227.
Old Jul 27, 2007 | 11:00 PM
ac5320's Avatar
The Brown dit
wow...my friends six speed maxima with intake and exhaust ran a 14.6...im surprised my car stock would run around that
Old Jul 27, 2007 | 11:41 PM
fsttyms1's Avatar
you should be in the 14s. My TL-P ran a 14.9 with just a exhaust and K&N filter. Did you gate shift?
Old Jul 28, 2007 | 12:43 AM
probmxstyle's Avatar
Dont worry, I ran a 15.7 in my TL-S. Was my first time at the track with a auto car. Went through the water box and had 0 traction in first or second. Second time i ran a 15.3, but had forgoten to turn off the traction control and the car kept going into limp mode. I guess next time I go I should be in the 14's from learning from my mistakes the first time.
Old Jul 28, 2007 | 07:57 AM
EL19's Avatar
i thnk the TLSruns 14.8 stock? u should work on ur launch...try torque braking oreasingoff the line...i have an 03TLS...went to the track when i had SRI, pulleys, and headers and ran a 14.4 wen back with a cold air and my exhaust resonators removedand ran a 14.1 also got better traction...gota unichip and spacers now & brand new plugs shouldbreak 13s...
Old Jul 28, 2007 | 08:02 AM
ac5320's Avatar
The Brown dit
wow. yeah i learned a lot from my first couple of times. next time i go ill have header and sri installed. i was thinking the car should run around 15 flat...what is torque breaking? and wat is gate shift?
Old Jul 28, 2007 | 08:03 AM
ac5320's Avatar
The Brown dit
it was weird my worse time was 15.7 but it was my best trap speed at 92
Old Jul 28, 2007 | 04:33 PM
Pun's Avatar
Pun
your problem is your 60' 2.45 and 2.46 you should lower the pressure in the tires some. Play with it or get some stickier tires. but just try adjusting the pressure for now, more mods are not always the answer.
Old Jul 28, 2007 | 05:21 PM
EL19's Avatar
b4 u put any mods on u may wanna break 14s...lower the pressure in the front tires, torque braking is when u press the brake with u left foot and giv the car a little gas to keep the tach around 2500-3500 rpms it givs u a better launch and makes it so ur tires dont spin as much...gate shifting is dropping the shifterall theway to D1 and working ur way up the gate as u go thru gears...so u would go D1,D2,D3 and u shouldnt haveto use D4 cuz on the type s 3rd gear goes to 110 well at least on mine hehe
Old Jul 28, 2007 | 05:28 PM
crazym0nkey's Avatar
What was the temperature outside? Humidity? Sometimes those two really change the times at the track. Did you have VSA turned off?
Torque braking is basically how most people launch at the track with our cars. Basically hold the brake petal with the left foot, and at the same time gas with the right foot. Maybe get up to about 2500 RPMs and when you see green, just release the brake.
My best time with my TL-S was 15.1 and this was all stock. My time is on the right side, and this was the first time I been the to the track. Probably could have got better, but my R/T is horrible and I let off the gas cause I got into the brackets and was trying to get my dialed time. Probably could have hit 14.8~9 if it got cooler.
Old Jul 30, 2007 | 02:51 AM
zerep6's Avatar
i have a 4speed tlp and did 16.6 stock @ 81mph
Old Jul 31, 2007 | 11:45 PM
ac5320's Avatar
The Brown dit
it was very humid and very hot that day...a lot of people had said that affected the run. Ill go up, again probably late this summer possibly pull better time.
Mike734
Dec 10, 2021 01:25 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
hashbrown
Sep 29, 2015 12:13 PM
flybyglass
Sep 24, 2015 01:12 PM
