Weird RPM "problem"
Old Aug 7, 2008 | 02:08 PM
villibg's Avatar
Weird RPM "problem"
Hey guys I have I bit of a RPM problem with my 2002 Tl type s.
Every time I start my car usually my RPM is around 750-850 witch is normal. After few seconds of working my RPM goes up and down. It goes up to around 1200 and goes down to almost to bellow 500, almost to the point that the car almost dies. This "problem" per say it happens only when the car is cold meaning that the car is been off for a while. After I run the car to certain temp the "problem" stops.
I'm thinking there is something that needs cleaning like injection or fuel strainer or some sort of a filter.
If you guys have suggestions please let me know. I'm pretty handy so I can do a lot of things on my car
Thanks in advance
Old Aug 7, 2008 | 02:14 PM
2N10s's Avatar
your IACV needs cleaning
Old Aug 7, 2008 | 02:22 PM
bass222000's Avatar
what is a IACV?? and how do you clean it?
Old Aug 7, 2008 | 02:26 PM
villibg's Avatar
What is IACV? If you dont mind me asking?
Old Aug 7, 2008 | 02:55 PM
phipark's Avatar
Not Asian
Idle Air Control Valve
Old Aug 7, 2008 | 02:56 PM
villibg's Avatar
Ok it is Idle Air Control Valve, but is it better to clean it or change it. And does anybody have any DIY on the IACV cleaning process
Old Aug 7, 2008 | 03:31 PM
2N10s's Avatar
i just cleaned mine instead of replacing it, it's not broken just clogged up. don't think there's a DIY for it but really just take it off, spray it down with some carb cleaner and slap it back on.
Old Aug 7, 2008 | 04:22 PM
villibg's Avatar
Thanks man i'll clean it within the next couple of days.
thanks for the help
Old Aug 7, 2008 | 04:54 PM
CAB NY's Avatar
Tri State ViP Crew
mine was doing that and i just sprayed it 2 weeks ago and so far it fine
Old Aug 7, 2008 | 05:01 PM
thevikas87's Avatar
Your mom is in
where is it located to remove and clean?
Old Aug 7, 2008 | 05:11 PM
CAB NY's Avatar
Tri State ViP Crew
i was told to just spray Carb cleaner down the TB and so far all good
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
