weight loss
weight loss
i took out all the plastic cosmetic trims in engine compartment, spare tire, and trunk floor lining to lose a total of 50 lbs. maybe its all in my head, but i thought the car is more responsive at low speed this morning.
any other ideas about losing weight without sacrafice functionality?? BTW, i lost 20 lbs. over the last three months, so that's no longer a viable option.
2000 laguna green TL
home made cold air induction
home made mesh hood and air dam grill
comptech sway bars
soon to have comptech sway bars and bridgestone RE730 225/55zr16 tires
comptech sway bars
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Originally posted by RAdams:
I've seen several roadrace cars that run Nitrogen in the tires instead of air.
changing ur rims from our ~25lb. ones to racing 14lb ones will reduce an insane amount of weight because its unsprung.. figure at least several hundred pounds. u can also change ur hood to a carbon fiber one and save about 50lbs on that. they have them available for the TL.
'02 Nighthawk TL-S
Comptech Springs / Comptech Headers
Alpine CVA-1005 Head Unit / Alpine CDA-7863 CD Player / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers / 20% Tint all-around
__________________
'00 Nighthawk TL
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Cross-Drilled Rotors / Pirelli SP7000 Tires / 35% Tint all-around
Pics of my TL and Fun/Crazy Pics
'02 Nighthawk TL-S
__________________
'00 Nighthawk TL
The Hindenburg's record was really, really good (at least until the last run into Lakehurst, NJ). The Humanity!!! Even then, New Jersey had a seamy reputation. A previous post had requested a Zeppelin finder as a much desired option missing on the Acura.
Originally posted by LagunaTL:
i took out all the plastic cosmetic trims in engine compartment, spare tire, and trunk floor lining to lose a total of 50 lbs...
Any other ideas about losing weight without sacrafice functionality??
DA
I hear if you take the regular air out of your tire and fill it with Helium, you will loose atleast 10lbs...cause it lighter air and gives your car lift Strip the paint and primer off too..cause that adds unwanted weight. Put a layer of slick50 on the outside to resist drag. This is the cheapest way to increase speed.
COmptech exhausts! You wouldn't believe how heavy the stock mufflers are. The Comptechs are solid stainless but lighter than stock. No exact figures though.
Also only keep 3 gallons of gas in the tank an you'll lose about 100 lbs.
2000 WDP 3.2TL non-NAV
AEM CAI
you know i think he is right on the weight problems though, it makes a big diffrence, i have had 3 ppl in the car and it has a difficult time accelerating, but laguna tl i dont think there is much you can do about weight reduction, maybe buy volk rims(light weight).....
Originally posted by Shoofin'TL:
Ed
Ed
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Nebraska Legal Darkest Tint
Goodyear Eagle HP Ultra Plus 225/55/16
Photos Of My RED HOT TL
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Red Hot TL on May 02, 2001 @ ]</font>
well, there ain't much you can do without scarfice something!!!
If you want, you can
1.take out the rear seat
2.take out the system
3.change all the glasses to plastic ones that is operated manually......
that will save you another 200 lb I guess
carbon fiber hood
99 MBP w/ alpine aftermarket nav/ vcr/ dreamcast (fm modulator so sound runs through speakers)/aem cai/aem pulley kit/comptech exhaust/ apexi v-afc/ eibach pro-kit
saturno_v
10-28-2015 06:57 PM
