Wax on windshield?
Old Jul 6, 2002 | 08:49 AM
SwampGas's Avatar
/etc/car
Question Wax on windshield?
Trying to figure out what is causing this...
Every couple of weeks, I get this waxy-like coating on the windshield...wipers just smear it. Washer fluid doesn't do anything to it.
I'm absolutely certain no wax got on to the windshield, the wipers, or anywhere near it. The washer reservior is also clean (to my knowledge)...only put washer fluid in it.
Would it hurt to put clean water in the tank and flush it out, or would running the pump that long damage the washer fluid sprayer?
Any ideas?
Old Jul 6, 2002 | 10:29 AM
SilverUA5's Avatar
Try some RainX. I don't think the problem is the windshield fluid. You can also try cleaning your wipers with some rubbing alcohol.
Old Jul 6, 2002 | 10:42 AM
NSXNEXT's Avatar
Try cleaning or replacing your wiper blades. I use Simple Green on a rag and wipe the blade. It should remove a lot of gunk from them.
Old Jul 6, 2002 | 02:10 PM
NsX Pilot's Avatar
being that you said you get the waxy coating on the WINDSHIELD ....may i suggest cleaning it with some dawn and fine steelwool....better yet read this thread and you decide what to do.... http://www.nsxprime.com/ubb/Forum1/HTML/004586.html
Old Jul 6, 2002 | 07:40 PM
AKRY's Avatar
MB-Fanatic w/TL-S
OR you can try use the finest sand paper you can find(2000 grand or something similar...1500 should do, too), spray some Windex and rub the window with sandpaper.... it would remove the oily film and polish up your windows......
Andy Kuo
Old Jul 6, 2002 | 08:08 PM
GOT PSI?'s Avatar
It's Go-Time.
Maybe bring your car into your local Acura dealer and check to see if your car VIN applies to get the TSB for replacing the washer fluid reservoir/wiper blades.
TheMuffinMan
Jun 2, 2022 07:11 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
rhdune16
Sep 28, 2015 11:31 AM
