Water In/Under Trunk Side Pockets
Old Apr 23, 2015 | 05:12 PM
Noticed a bit of water in the trunk side pockets the other day & pulled them out. There was water under them in the dip there, but not enough to spill over into the spare tire well.
None of the carpets/side panels have any moisture on them. Is there a clogged drain I need to check?
Also, I think it's been this way since before I had the car. I got a flat a few years ago & had to shear off the spare tire holder because the threads were completely seized/rusted in.
Old Apr 23, 2015 | 07:06 PM
Skirmich's Avatar
Its weird because the rain drains are basically the spaces between the Trunk Gasket and the Car Body... There aren't any hidden tubes or anything like with the sun-roof.
Old Apr 23, 2015 | 08:37 PM
01acls's Avatar
There is a moonroof drain tube on the left side of the rear quarter panel. You might want to check that. It runs from the left rear corner of the moon roof down the inside of the sail panel into the trunk side pocket area and plugs into a valve that's attached to the sheet metal directing the water outside under the left rear bumper. It could be plugged up or knock loose feeding water to inside instead of outside.
It's worth a shot.
Old Apr 24, 2015 | 07:49 AM
fsttyms1's Avatar
^ Check the moon roof drain tube, also inspect the tail light gaskets.
Old Apr 24, 2015 | 07:56 AM
01acls's Avatar
If those are fine then its prob your back glass.
Old Apr 24, 2015 | 10:27 AM
the-G-ride's Avatar
This ^^^ I had a leak in my trunk for years in the same spot as well as in the spare tire area. I could never figure it out until I was told to change the tail light gaskets. Changed both of them and never had a problem since.
Old Apr 24, 2015 | 02:17 PM
fsttyms1's Avatar
Or one of the pinch weld seems in the wheel well
Old Apr 24, 2015 | 04:34 PM
Thanks, I'll check the taillights first, probably the easiest.
Old Apr 25, 2015 | 07:37 AM
losymis's Avatar
Sunroof drain tube....fixed my problem
BoricuaTL
Apr 8, 2016 01:08 PM
mugen_kid
Nov 13, 2015 10:38 PM
PortlandRL
Sep 14, 2015 12:01 PM
EE4Life
Sep 11, 2015 10:13 PM
