Water Problems
Old Jun 14, 2003 | 04:36 PM
Mr Zipps's Avatar
Water Problems
I was resealing my headlights after one of the fogged and it started pouring outside. Fu(k.....
So by the time I got out there to cover everything up all the wire harness were wet.
What can I do know? Do I just wait til they dry up? Do I use a hairdryer to hurry the process? So I keep my lights off for a while?
HELPPPP?????????
Old Jun 14, 2003 | 04:50 PM
hzm82's Avatar
Damn you don't have a garage? Wipe the stuff up with a towel and let it dry. If you use a hairdryer don't use high heat setting and just blow it to get the water out of the nooks and crany.
Old Jun 14, 2003 | 04:52 PM
Tom Blasing's Avatar
is the Mighty Favog
I would keep them off for a while if you can. The next very aarid and dry day I would first blow them out with an air compressor then use the hair dryer. If you have some silica gell packs around you could leave them in there for a couple days.
The key here is to re-seal them whem it's the dryest air outside. This will minimize the moisture inside the assembly when you put the unit back in and re-install the bulb.
Hope this helps!
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
STL TL-S
Sep 23, 2015 08:52 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
