warranty on tranny?
Old 11-02-2005 | 07:57 PM
daniel1120's Avatar
7th Gear
Question warranty on tranny?
how long does the warranty for the transmission last? 50,000 miles or 100,000 miles? are there any high performance tranny out there that can replace the oem one so we don't have to keep worrying about it slippin.?
Old 11-02-2005 | 08:21 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
7 years or 100,000 miles.
Old 11-02-2005 | 08:59 PM
fsttyms1's Avatar
the actual warranty on the tranny is 12 month 12k miles. BUT if you are still under the 7 year 100k mark on the car then its good for those #'s
Old 11-05-2005 | 06:35 AM
JRA2000TL's Avatar
It's 7/100 but if your car is a repeat offender with a bad tranny, it doesn't matter....Acura will still put one in for free. Don't let the dealer tell you otherwise--I work for one. If they don't it's because your dealer is not trying to do anything for you. Acura warranty hotline will approve one even after 7/100. There are no trannys available for customer pay for the 00-03 TLs. Acura has them all for warranty recalls. What they might do is buy the part and make you pay the labor. Depends on how much the dealer goes to bat for you...trust me on this.
Old 11-05-2005 | 06:41 PM
fsttyms1's Avatar
The tranny it self does not have a 7 year 100k warranty on it. As lon as your car is within the 7 years or 100k from the original purchase date they will keep replacing them for free. If you are past 100k and have one installed the warranty on the tranny is only 12k miles 12 month. some times acura will good will it past 100k.
Old 11-05-2005 | 06:48 PM
pzero23's Avatar
Fsttyms1 did you have your warranty work done at Acura of Brookfield ??? and did they give you a loaner??
Old 11-05-2005 | 07:12 PM
fsttyms1's Avatar
No i hate brookfield. The were asses to me. I got all my service work done at Zimbrick in middleton. Yes i got a loaner every time i went there
Old 11-06-2005 | 07:59 PM
mtxbass1's Avatar
My 2000 TL has 39,580 miles on it. I bought the car used. Would I still be covered under the 7/100 warranty even though I bought it used?
Old 11-06-2005 | 08:01 PM
fla-tls's Avatar
On the way!
Yes it would.
Old 11-06-2005 | 09:15 PM
fsttyms1's Avatar
Yes unless it has a salvaged title
Old 11-08-2005 | 01:48 PM
JRA2000TL's Avatar
Yes, the part does have a 12/12 warranty on the replacement, but what I meant was that you can still get it replaced if you're inthe 7/100 period; you can also get a goodwill after the 100k period.
Old 11-08-2005 | 02:58 PM
fsttyms1's Avatar
correct, typically they start limiting it around 115k, and they they usually dont give you a warranty on the replacement at all.
Pham Alvan
05-18-2021 07:48 AM
Charles Bennett
01-28-2018 09:53 PM
xsilverhawkx
10-05-2015 12:00 PM
hashbrown
09-29-2015 01:13 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 01:33 PM
Quick Reply: warranty on tranny?
