VTEC vs. iVTEC
VTEC vs. iVTEC
I should do some research on this but I'm tired right now.
First of all I actually have two questions.
1: What unlocks the extra hp on the TL-S in comparison to the TL-P?
2: What is the difference between VTEC and iVTEC?
Re: VTEC vs. iVTEC
Type S has a higher compression ratio then the P.
Originally posted by MotionEffects
VTEC kickes in at 4800 rpm for our cars
iVTEC i=Intelligence VTEC. it kicks in when need, at diff rpm
Originally posted by hurricanevez VTEC = SOHC = single overhead cam
Originally posted by silverua5 Type S has a higher compression ratio then the P.
EVERY i-VTEC motor is a DOHC; there are two exceptions to the VTEC = SOHC those are the NSX and the S2000 go figure
the 2002 cr-v engine is a 2.4 liter DOHC i-VTEC
Originally posted by asiankidd
i alpologize for my mistake then the 1.7 must be in the civic but im not sure if it i-vtec or not...none the less i-vtec just migh tmake it into the soch family....
The new Civic Si is 2.0 iVTEC.
it's not about that...
i-VTEC is the modified version of the current VTEC and the future hondas will use i-VTEC since then...
it smoothen the kick from the VTEC kicking in...and it's a newer version of the VTEC...so...how can i say??
the very nature of variable cam phasing REQUIRES DUAL CAMSHAFTS!!!! Hello!!!!
Go do some goddamn research - all of you - and find out how VTEC actually works, WHAT cams are (they're not cameras, which is probably what you think cam is short for), what DOHC is, what SOHC is, how to count to 2, how to spell, learn some grammar, learn some typing skills, and ENGLISH.
Originally posted by gocrazyw/TL
HOW STUPID CAN YOU POSSIBLY BE? Stop talking out of your ass, dumb****. SOHC VTEC has existed probably longer than you've been alive. And to the person saying that the difference is SOHC and DOHC, you're a complete idiot as well. DOHC VTEC: GS-R (B17A as well as B18C1), Type-R, CR-V and I believe Odyssey. Shut up before you embarrass yourself some more. Damn some of you guys are complete dumbasses.
CANT YOU EVEN F U C KING READ? MY POST REFERS TO iVTEC NOT VTEC YOU F U C K I N G ILLITERATE F U C K. DO YOU THINK IM AS STUPID AS YOU? MY ACCORD AND MY TL ARE SOHC VTEC SO WHY THE F U C K WOULD I SAY EVERY ENGINE WITH VTEC MUST BE DOHC!!!!!
DONT YOU F U C K I N G FEEL STUPID NOW YOU DUMB S H I T
Originally posted by TuRb0MiKeY
WHAT A DUMB F U C K I N C U N T YOU ARE. ONLY IVTEC ENGINES HAVE VARIABLE CAM PHASING. STANDARD VTEC ENGINES ONLY HAVE VARIABLE VALVE TIMING. SINCE YOU'RE SO F U C KIN SMART YOU SHOULD KNOW THAT. THERE IS NO COST-EFFECTIVE METHOD TO INCLUDE VARIABLE CAM PHASING ON A SINGLE CAM BECAUSE THE EXHAUST LOBES AND INTAKE LOBES MUST BE SEPARATED. READ THE F U C K ING TRHEAD THROUGH BEFORE YOU OPEN YOUR FAT MOUTH YOU STUPID F U C K I N G NOOB
JON LERD
Originally posted by stiletto
vtec, ivtec, vanos, and all the other acronyms... They are ultimately just marketing ploys.
Lighten up and enjoy your engines forcryin'outloud.
I would have to agree with you on the fact that this discussion has become too much of an arguement but these acronyms are more than "just marketing ploys." They allow naturally aspirated engines to produce the same amount of hp as traditional engines could with almost half the displacement.
And don't forgest VVT-i and its counterpart VVTL-i.
IBankMouse
06-13-2020 12:53 PM
