Vibration at diffrent speeds
Old Sep 19, 2007 | 08:37 AM
kuzdu's Avatar
Styl1n
Hey guys hows it going, well here is the issues I am having. I just out on my BBK from crabs everything is fin for two weeks and I notice a vibration only when braking from 60 or above. From 55 and below there is no vibration or anything. When I drive and hit 60 to 80 there is a vibration in the steering wheel, after 80 it is gone. My two lower ball joints are bad and will be replaced this weekend. Does anyone think the wheel bearings may be bad as well? Has anyone had this issue.
Old Sep 19, 2007 | 10:37 AM
probmxstyle's Avatar
Sounds like something my car does between 60 and 80. but mine doesnt just do it when braking. What are your ball joints doing that made you think there bad?
Old Sep 19, 2007 | 10:54 AM
kuzdu's Avatar
Styl1n
he checked the lower ball joint and both of them have a lot of play.
Old Sep 19, 2007 | 11:03 AM
01tl4tl's Avatar
Fix that and dont drive much until then- danger warning danger- check the uppers too- its a ~while you were in there anyway~ type of job,
to make sure the steering stays tight- that solves vibration and wobble
Old Sep 19, 2007 | 11:22 AM
acutee's Avatar
You probably have at least two problems. Warpped Rotor, and wheel balanced. If these two probls are fixed, then look at other members' suggestions.
Old Sep 19, 2007 | 12:17 PM
01tl4tl's Avatar
If the ball joints are known to be bad- thats where you start replacing parts--
before thinking your new rotors are crap
Old Sep 19, 2007 | 12:56 PM
kuzdu's Avatar
Styl1n
my big brake kit is two weeks old and my wheels were balanced perfect, so that leave a suspension component that is the problem....that is what i am leaning towards now
Old Sep 19, 2007 | 04:47 PM
01tl4tl's Avatar
No- its a steering part prob- the BALL JOINTS- will you just get them replaced and an alignment and be done with it!!!
A good shop would never have installed the brakes without making you fix the ball joints- it can be life threatening especially while out playing with the new brakes
Old Sep 19, 2007 | 05:53 PM
fsttyms1's Avatar
Were being the key word. Just because they were balanced doesnt mean that they cant become unbalanced.
Old Sep 20, 2007 | 05:11 AM
TOTAL~LUSH's Avatar
mine is like that too but it is really bad when its cold out and sat parked for 10 hours.
Old Sep 20, 2007 | 08:47 AM
kuzdu's Avatar
Styl1n
actually the wheels were balanced last week before the bbk went on. just trying to narrow down things that need to be looked at
Old Sep 20, 2007 | 09:16 AM
dnd2984's Avatar
HOw much do new ball joints cost. I am getting a slight vibration at 80mph + but smooth at 75 mph
Old Sep 20, 2007 | 09:30 AM
kuzdu's Avatar
Styl1n
it is $16 each, i get them at discount price. OEM too
Old Sep 20, 2007 | 09:32 AM
dnd2984's Avatar
my steering wheel also vibrates at 55 to 65. Is that balancing or bent rim?
Old Sep 20, 2007 | 02:14 PM
dnd2984's Avatar
Are the ball joints hard to replace. The price of $16 is not bad.
Old Sep 21, 2007 | 05:04 AM
TOTAL~LUSH's Avatar
if like most hondas they are pretty straight foreward. just a sunday afternoon and a case of beer kinda deal.
Old Sep 21, 2007 | 05:36 AM
acitydweller's Avatar
Bear in mind you do not need OEM beer either
Old Sep 21, 2007 | 06:27 AM
kuzdu's Avatar
Styl1n
hmm beer.....prob some henny and ginger the job goes much quicker......sat afternoon i will be doing it
Old Sep 21, 2007 | 08:19 AM
dnd2984's Avatar
Your avi is great.
Old Sep 21, 2007 | 10:27 AM
kuzdu's Avatar
Styl1n
tanx
Old Sep 21, 2007 | 03:06 PM
TOTAL~LUSH's Avatar
Originally Posted by dnd2984
Your avi is great.
thanks but i guess its against a bunch of at work rules and crappy shit like that. personally if your at work and on acurazine your not doing your job!
Old Sep 21, 2007 | 11:16 PM
jayunsplanet's Avatar
Uh ohs...
I've been having this issue for a month or so now. All the sudden one day my steering felt kind of "lose". It used to be pretty tight and predictable but now I can turn the wheel just a little and the car doesn't respond right away. It just feels a little mushy. (This might just be my mind playing tricks on me. We'll see) At 60+ I have a bad shake. (I also have a worse shake/shudder when braking -- which is probably warped OEM rotors...) My car is currently at my Acura dealer getting my headlight fixed and new B-pillar trim. I also had them balance my new CL-S wheels and I'm having them check my pads & rotors. I hope the wheel balance fixes it. So we'll see what they say tomorrow when they call. Hopefully they will have noticed the problem and will have a diagnosis or fix.
Old Sep 30, 2007 | 08:51 PM
kuzdu's Avatar
Styl1n
hey jayunsplanet did acura tell you what the prolem with your car is?
Old Oct 1, 2007 | 11:46 AM
gotdebt's Avatar
I recently purchased an '02 TL and have the same problem. It is more pronounced with heavy braking. My car jocks friends think it's a rotor. How much would you estimate it would cost to replace a warped rotor?
Old Apr 2, 2008 | 09:13 PM
NighthawkBlack's Avatar
Are there aftermarket ball joints that would maybe last longer?
Old Apr 2, 2008 | 09:54 PM
03aspec's Avatar
rotors should always be replaced in pairs...
and my car has a weird vibration only above 40mph.. might neet a wheel balance.not sure..
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
