UR pulley - belt help
Sig Rho's Finest
hey guys im going to have my pulley put in this thursday. what are the belts that i need? i cant use my stocks one correct!?!?! thanks
This pulley kit Part#02061100_ contains a crank pulley: underdrive stock belt layout (Ultra S) Part# 0206110. Check that the part number matches the
number engraved on the back of the pulley.
Installation Instructions
1997-03 CL All / 1999-03 TL All / 2001-03 MDX / 1998-03 Accord V6 / 1999-03 Odyssey V6
• Alternator & A/C Belt: Accord, CL & TL: Use Gates K060441 (44 5/8” or 1135MM)
MDX: Use Gates K060445 (45.25” or 1150MM), alternate belt size use K060441 (44 5/8” or 1135MM).
Odyssey: Use Gates K060445 (45.25” or 1150MM)
• Power Steering Belt: Use Gates K040425 (43 1/8” or 1095MM)
O.G.
Here is the picture of the belt you are going to need for the crank pulley. It is the Gates K060441 and I got it from Napa auto store. It was like @ $12. I haven't installed mine yet:
Initial D
Discount Code on rockauto.com
If you want to save a trip to your local auto store you can order the two belts needed from rockauto.com, total is about $23 shipped. Just use the search part option and enter "K060441" and "K040425".
- When you places an order at www.rockauto.com and enters your discount code 150222154776 in the "How did you hear about us" line of the shopping cart, you will receive an immediate 5% discount on that order.
- The discount code expires on December 28, 2004;
O.G.
Sig Rho's Finest
Originally Posted by BlackShadow
Correct me if I am wrong...if you are only going to get the crank pulley then all you need is the Gates belt K060441, right? Because this is the only pulley that actually gives you power. The others are purely for cosmetics, right?
yea ur rite. seems like every1 has the same say
Is there a UR pulley set that are the same size as stock but lighter? I'm not really too thrilled to underdrive but would like the lighter set for better efficiency.
USDM UA5 A-Spec
I'm getting my UR crank pulley this week, but I'm very certain from other UR pulley TL owners that they are all the same size, unlike AEM which is actually larger. The only difference is that it has holes cut into it to reduce weight. Correct me if I'm wrong, but I went with UR pulleys because people told me they are the same size as stock.
u need 2 belts for the crank pulley , and i know UR is like Nike but i took a risk and got a pulley off ebay for $35 and its working just fin in my 00TL , feels better off the line, the top end didnt change a whole lot
Initial D
I just got the pulley yesterday. Installation instruction lists two belts to be replaced. Once you got the pulley you will understand why two belts - it has two grooves.
O.G.
Or do I need another different belt? If so, what is the number?
BTW, I just bought the crank pulley.
You need 1 Gates K060441 belt, and you need 1 Gates K040425 belt.
O.G.
does anybody know if autozone or pepboys sells these belts?!
Originally Posted by moahdriven
i kno this threads old, but neone kno if these belts would work for the Megan Crank Pulley?
