upper strut bar
^yes. there is a member on the black market that is selling a comptech strut bar. https://acurazine.com/forums/car-parts-sale-361/sold-fs-2g-tl-cl-comptech-sway-ti-strut-bar-387417/
Originally Posted by Rajca
^yes. there is a member on the black market that is selling a comptech strut bar. https://acurazine.com/forums/showthread.php?t=387417
because you have not looked closely at the stock one and where it bolts up- what its INTENTION is versus the action happening
compare with the addition of Cusco which uses the remaining 3 strut tower bolts and goes direct to the other strut tower- way better rigidity and locates the strut tops in relation to each other
The lower bar locates the lower suspension points and strengthens the lower frame rails and suspension mount points
I use the lower cusco bar- $85 and the upper cusco OS- oval shaped (pressed for better strength) $150
see vender MrHeelToe- www.heeltoeauto.com for both those items
Originally Posted by seanmcd
I'm confused - why add one if there is already one there form the factory? It seems pretty solid?
no seriously... adding one instead of replacing it will increase rigidity..... equivalent to a larger thicker one which replaces the stock
You ~feel~ the immediate improvement with the lower bar- the car stops flexing into corners. and passengers dont feel an oppposite roll to the direction of the turn.
The upper is a definete help for those that push the car harder- or are doing shock/suspension upgrades. You need a stable base for the shocks and tires to do their work, a fixed spatial location to each other.
So my answer is Yes the upper bar is good, and combined with the lower is great.
If I had to make a choice of 1 to started- get the lower
Comptech >*
BTW I know its off topic but I have both upper and lower (front and back) FS in the BST section ..
back on topic:
The lower bar goes across the frame rails- right where they go from straight to curved around the engine and transmission.
There are 2 big bolts there- the bar goes across and fixes the frame in place relative to each side- to reduce flex.
Its cheaper because its flat steel and a simple design.
The upper is a far more complex piece of reformed round steel stock and thus cost more.
You can install it yourself. I got my Neuspeed bar used for $85. You don't need to buy anything else, but it would help a ton if you had a hydraulic jack. Many people need to jack the car up from the front center jack point all the way on the stock jack to get it to fit.
the upper bar requires a socket set iirc 12 or 14mm- undo 3 nuts of the 5 on top of the shock tower. The ones the stock bar is not using.
install bar- replace nuts, tighten - may come with new ones- tighten adjuster ends of bar. Done
Total time 5 minutes
Lower bar- helps to own car ramps for oil changes- so I had those.
Drive the car up on them-place block behind rear wheel to prevent roll off!!!!
undo the 2 big bolts= need 3 or 4 foot long breaker bar- entension pipe like a jack handle to get enough leverage- they are tight tight tight
make sure they are like that once you are done as well~
Same thing- 2 bolts- put bar in place and re-install bolts- tighten fully- tighten end adjusters- drive backwards off the ramps- go drive and do some lane changes quickly and some cloverleaf on ramps- move on and off the line and feel the differance from before- the low cost is suddenly the best cheap mod you have done so far. You will tell your friends.
Sort of like a recent thread on Does Seafoam work???- the doubting OP came back and said mileage improved, car runs smoother- he is now a believer
they do different things- sway bars are about weight transfer and body roll
In my opinion you need to stiffen the chassis in order for the suspension and tires to better and fully do their jobs.
I have not done the rsb so I cant say how much it helps. Been thinking of installing poly bushing on the stock bar- have to keep it wife driveable for now.
I do have a 1.5-1.75" drop on Tein SS and that rocks!
May be Tein SS in the future?
How easy are they too adjust and what settings are you currently
riding on..?(Wife compliable).
Originally Posted by chrismeoli
ended up being a good discussion, fasttyms not a fan of Cusco? what do you think of rear sway bar upgrade?
Rear sway bar upgrade
Fast Times WON=
Our GURU and gen2 TL Moderator- he knows many things and has over 250,000 miles on his TL- not to mention some special mods to the car, like a different motor with manual trans
on gen2 TL forum..
Originally Posted by fsttyms1
Its not that im not a fan, I would want a bar that utilizes the stock 4 point mounting, or a bar that mounts to 4 points like the comptech. That are more rigid and do a better job than those that just connect the 2 towers.
But i personally would upgrade both ends.
What about changing the OE bushings to Polyurethane, Will this really make a difference?
lanechanger
Oct 13, 2015 10:56 AM
adreano17
Sep 29, 2015 08:48 AM
