Updated 5AT Transmission Launch Date
Can someone please tell me when the "updated" 5AT transmissions became avaliable for the dealerships to install?
Thanks.
Thanks.
ChairmanMaoSaysRTFM
Thanks.
Thanks.
SSTS
From my understanding the parts came available in feb 05
What are the differences between the "updated" transmission from the dealer? I had my transmission replaced before February 2005. Should I go back and get it replaced again with an "updated" one?
there are supposed to be different plates for the clutches and a different shaft. And you cant just walk in and ask for it to be replaced with a new one. Yours has to be toast for them to do it
I bought my 2000 TL from my friend who was a mechanic at Acura and he replaced the transmission by himself before February 2005. It turns out that since he did it himself, the Acura database states that I did not perform the transmission recall. Hence, I still get notices in the mail about coming in to the dealership and getting my transmission replaced. I have been ignoring it because of the hassle and the fact that they would just put in the same junk as before, but maybe this "updated" transmission will be better.
Thanks for the fast response!!!
Thanks.
From what I was told, the updated transmissions were avaliable after the oil jet recall bulletin was released ???
From my understanding, the updated transmissions had the internal oil jet revision, thus the updated transmission did not need an oil jet to be installed. (one covering fill hole)
If the updated transmission launched in 2/05, then all of the '04 TLs would have the failure-prone transmissions, which I don't think is the case.
![Run](https://acurazine.com/forums/images/smilies/run.gif)
6G TLX-S
Thanks.
If the updated transmission launched in 2/05, then all of the '04 TLs would have the failure-prone transmissions, which I don't think is the case.![Run](https://acurazine.com/forums/images/smilies/run.gif)
Received 1,080 Likes
The '04 and up TL's are using drive-by-wire throttle and diferent engine management system. So the 3rd gen TL transmissions won't have the same 3rd gear clutch pack failure as for the 2nd gen.
Que'?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
They have a different stereo and oh wait, they have a different steering wheel. Maybe that's why they don't have tranny failures.
Thanks.
Originally Posted by NSXNEXT
Que'?
What does DBW and a different EMS have to do with a physical clutch pack in the transmission?
6G TLX-S
Let me repeat what I have said numerous times before inside various transmission-related threads.
The majority of the 2nd gen transmission failures is related to the internal 3rd gear clutch pack which is slowly coming apart due to overheating and inadequet lubricant cooling. The small broke-off pieces then further block the filter and also the already insuficient oil passageways, thereby creating more and more heat and resulting in terminal tranny failure.
According to the official tranny failure investigation report (which was first published on the Acura-CL tranny forum a few years back) submitted by Honda to the NHTSA, overheating was the culprit to the 3rd gear clutch failure. Some 3rd gear clutch plates were found to be out of tolerance. Tests conducted by Honda revealed that repeated 3/4 to full throttle 2rd to 3rd gear upshifts as well as 5th to 3rd gear downshifts would raise the tranny internal temperature by some alarmingly huge number. Compounded by the inadequet fluid flow rate inside the tranny, the 3rd gear clutch pack would become cooked and disintegrated after a period of time.
Initially Honda replaced failed trannies with rebuillt units using (better tolerance) 3rd gear clutch plates, more oil passageways to increase cooling, etc. However, these rebuilt units continues to fail the same way. So later on, tranny replacement also included replacing the PCM which contained revised software program. Then repeated tranny failures dropped considerably, but is still happening at a much lesser rate.
Below is all my speculation from what Honda has done so far.
In order to reduce the heat generated from the full throttle 2-3 upshift and 5-3 downshift, the engine output has to be reduced considerably during the gear disengage/engage periods. The revised PCM program functions to retard the ignition timing and modify the fuel injection timing to reduce the engine output. However, since the throttle is mechanical, the throttle plate is still wide open when the driver presses the throttle pedal to the floor. Once the throttle plate is wide open, intake air flow is at the maximum. There is only so much that the timings can be retarded (which is evidently not enough) while the mechanical throttle is forced wide open and sucking in maximum volume of air when trying desperately to reduce engine output.
But with drive-by-wire throttle system, even if the throttle pedal is pressed to the floor, the PCM has full control of the throttle opening electronically, and can reduce or shut off the opening completely to effectively reduce engine output to a safe level during "fatal" shifts. As a result, the 3rd gen tranny is not going to have the same heat related failures as in the 2nd gen tranny.
navtool.com
31
11-16-2015 08:30 PM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
