update on possible transmission failure? egr?
Old Jul 30, 2010 | 08:16 PM
earthbound741's Avatar
Acura Newbe
hey guys,
well my other post was closed becuase i mentioned i was looking for a transmission but you guys went on to help me figure out if its really broken. Today i went to autozone and got the codes checked. Well the P0420 is still there as it was for the last 2.5 years =P. Though i am not sure who posted something about the egr and yes the code was there oddly. I am going to go ahead and attempt to clean it as I saw a tutorial on this site before. I will keep you guys up to date as soon as i get that done.
Old Jul 30, 2010 | 10:23 PM
01tl4tl's Avatar
do the complete egr port cleaning by removal of intake manifold
good luck!
Old Jul 31, 2010 | 12:43 AM
Willie3.5's Avatar
SixSpeedDreamin'
Cleaning the EGR does a lot, well at least it did for me.I have a 99 TL and Acura said the recall had been done, but as soon as I flipped my intake manifold over it was clear as day that Acura had lied...99 TL's intake manifolds are different from the 00-03. In the 99's a tube was suppose to be put in the EGR valve hole, but I didn't have one in mine once I took off the manifold...anyway the response from the engine is worth cleaning...GOOD LUCK!
Old Jul 31, 2010 | 10:36 AM
YeuEmMaiMai's Avatar
^ honda abandoned that fix quite some time ago..........
Old Jul 31, 2010 | 10:57 AM
01tl4tl's Avatar
the 99s recall on the single port egr was to slightly enlarge the 1 hole with an 8 mm drill bit and put a metal tube insert with smooth sides in the hole.- thinking less way for crud to grab on
It was a bandaid at best, not a fix at all
all gen2s need egr port cleaning via manifold removal every 75kmiles, or less for 99 with 1 port
later years have 6 and they still plug--blame E10 added gasline for poor combustion and extra byproduct loading
agupta3224
May 23, 2017 08:30 AM
joflewbyu2
Oct 8, 2015 11:16 AM
flyromeo3
Sep 24, 2015 11:24 PM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
