Update on fast brake big brake Kits!! for 99+ CL/TL
Old 10-31-2002, 07:47 AM
SilverBulletCLS's Avatar
Ok here's what we know:
Two piece rotors with aluminum hat
12.2" diameter
1.1" or 1.25" thickness
directionsl vanes to promote for better cooling
brake line adaptors(allow for use of stock lines or aftermarket market lines that fit stock calipers)
adaptor hardware
wilwood poly D compound brake pads
Two piece wilwood superlite 4 piston calipers
all required mounting hardware
Fitment is being confirmed. With the 12.2" 16" rims is probably out of the question... although there's pretty high level of confidence that it will fit stock 17" rims. We are going for the 1.25" thick rotors, but if that doesn't work, we will do 1.1". With directional vanes, better cooling will be promoted which should help decrease warping issues. Plus with the larger rotor diameter, that should help as well.
Pricing will more than likely be sub $1000 for the kit. Slotting and x-drilling is a $100 option.
cycdaniel
12-17-2019 10:58 AM
HOWELLiNC
10-19-2015 03:26 PM
HOWELLiNC
09-10-2015 01:39 PM
nuldabz
09-03-2015 05:49 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: Update on fast brake big brake Kits!! for 99+ CL/TL
