Under the Engine Cover...
Old Nov 25, 2004 | 02:05 PM
Means17TL's Avatar
I just removed the plastic and the metal engine cover and noticed a orange like fluid underneath...what is this fluid? and should it be there? it seemed to me like it could be a lubricant of some sort for the bolts underneath...
Thanks in advance
Means
Old Nov 25, 2004 | 06:32 PM
Means17TL's Avatar
bump---anyone know what it is?
Old Nov 25, 2004 | 08:03 PM
moahdriven's Avatar
i
not sure what it is but i know its supposed to be there. If you remove the intake tube from the throttle body and look in you'll notice and orange hue.
Old Nov 25, 2004 | 08:35 PM
99TLKID's Avatar
L33t Sk8er
Is anything under there showing signs of rust? That would be my only guess! Check everything over well and maker sure that stuff is not rusting........and try to keep that as dry as you can.
Old Nov 25, 2004 | 08:39 PM
fsttyms1's Avatar
there shouldnt be any orange like fluid any where. period. whipe it up, drive the car for acouple days and recheck it
Old Nov 25, 2004 | 08:40 PM
Means17TL's Avatar
Nope...no rust, everything is clean...the fluid is clear and has an orange color to it...all the bolts under the covers are clean, look like new bolts to me too...whatr makes you say that i should keep it dry????
Old Nov 25, 2004 | 08:43 PM
fsttyms1's Avatar
just whipe it off and drive it for acouple days. then recheck. the TL doesnt have any fluids like that. and where under the plastic cover was it?
Old Nov 25, 2004 | 08:48 PM
Means17TL's Avatar
i removed the plastic cover then i removed the metal cover thats held down by 8 boolts i believe and in that pan-look-alike atop the engine is here the fluid is...
I was surprised to see the fluid...but its a good 2-3 centimeters deep as well...
hopefully tomorrow morning i can take a pic and post.
Old Nov 25, 2004 | 08:55 PM
fsttyms1's Avatar
dude that INSIDE your intake
did it look like this underneath
Old Nov 25, 2004 | 09:00 PM
Means17TL's Avatar
underneath, thats exactly what it looks like, but there is fluid in there also
Old Nov 25, 2004 | 09:05 PM
fsttyms1's Avatar
how much fluid. you may find moisture from teh exhaust in there. that piece is part of the egr system. possibly some oil mixed in too
Means17TL's Avatar
a good 2-3 cm of fluid...
Old Nov 25, 2004 | 09:11 PM
fsttyms1's Avatar
like down here? its perfectly normal. its supposed to be there. its oil
Old Nov 25, 2004 | 09:13 PM
Means17TL's Avatar
yep, exactly down there, but there's a lot more in mine than there seems to be in yours...
Old Nov 25, 2004 | 09:16 PM
fsttyms1's Avatar
thats fine. it should be there. nothing to worry about
Old Nov 25, 2004 | 09:19 PM
Means17TL's Avatar
thanks for the help FST...
Rep PTS to you...
Old Nov 25, 2004 | 09:26 PM
fsttyms1's Avatar
no problem! and thanks!
Old Nov 25, 2004 | 10:48 PM
ou sig's Avatar
Boomer SOONER
fsttyms1 you are amazing with all your detailed pictures!!! do you have a spare TL sitting around you at all times so you can take it apart???
Old Nov 26, 2004 | 08:18 AM
Street Spirit's Avatar
LOL!! I know, eh?!!
Always a great source of info, kris!
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
