uh oh, messed up my temp needle
well went to install the indiglo gauges today, all good, but i messed theneedle up. when the cars on, it moves up a bit, but slowly, and gives wrong readings all the time, its not sticking, its the needle, so if i buy another cluster, can i just remove the fuel/temp gauge portion and replace it on the exsisting one?
yes you can, just undo the metal clip/ clamp, on the back of the board and push on those and it will pop out
I don't know what year you have, but for the 99, make sure you get one for it, not the 00-03. It will not give work.
i pulled it out, lol i know jackass move, i was aggrivated as fuck, cuz it kept stickin, u sure the 00 wont work? arg, i got one off ebay for 20 bucks too, gotta buy a 99 then...thanks
are you sure its not sticking?
yea, and now the rpm and mileage are sticking, for the mph, it sticks between 60-80 and 140+ and rpm jumps around n s hit, the gauges werent cut that good either, i noticed it when installin but though tit wouldnt matter much......so yea got me a new cluster now, and new gauges commin off pro parts. they gauges fit good? or what..
trill recognize trill
when i said it wasnt cut good, u know how theres the actual gauge face, then the little oval/cirlce holes so it can sit properly? mine were not cut proper, and didnt fit exact, or straight, so i had to trim it a bit,
btw i got a 2000 gauge cluster, the temp/fuel gauge wont work no matter what? or r u just sayin that cuz of the model year difference, anyone know for sure? thanks for de help.]
i own a 99.
i own a 99.
Opium den in
My "P" SpAnKs YouR "S"
Originally Posted by Final
Isnt it impossible to recailbrate the tach/speedometer needles once theyre tampered with...?
Originally Posted by sojue
My speedometer needle is good. I messed up the temp needle and gas needle. The other two needles are still good.
lanechanger
10-13-2015 10:56 AM
