two questions
the car requires 91 or 93-94 if thats what they sell in your area
Since its been run on 87 there will be excess carbon loading of the valves and pistons!
Throw a can of seafoam in 1/2 tank gas and another can in the intake main vac port at the TB connection to intake manifold- see DIY section
Will clean all the crud out and restore like new performance~
Probably needs new sparkplugs too- NGK Iridium or NGK Iridium IX
87 is a killer on high compression engine- yes the computer will compensate by retarding timing- leading to other problems
Also the quarter was 15's and you wont achieve those numbers with 87
im not racing, someone just asked me the 0-60 and i wanted to say atelat a semi acurate number.
should i seafoam before i put in the better gas?
also, can i just add it in, or would them mixing somehow hurt the engine?
-max seafoam use for driving method is: 2 ounces per gallon of gas (more is not more effective- per seafoam)
thats 1 can to just under 1/2 tank
may want to repeat that in a month, and/or do the intake vac method twice as well- then good for a year
very simple DIY and acts instantly, while gas method takes days
you still need to do the gas method to clean fuel sprayers from the inside even if you do the intake vac
This explains my situation. Ive had the car for only like a year and a half, but my parents never filled 91. 89 for the first couple years and then 87. And they have me fill 87 too. Ive ran dynolicious on my iphone, the best ive gotten is 8.2 seconds. I have a 00tl, with 165,000 miles and its stock. Tires may also slow it down, I dunno really how my tires are compared to others. I have fuzion HRi. But my tl should be doing mid 7's if it was brand new/stock. So im a ltl off.
ok, so fill with 91, drive tell its at a quarter tank, then do the seafoam diy. wheres a good place to buy seafoam
seafoam is available at most parts stores- walmart etc
8-10 bucks a can
Please dont use more than 2 ounces per gallon of gas - throwing away your money.
thats 1 can in 1/2 tank!
8-10 bucks a can
and edmunds says that a tlp shud do 7.7 0-60. type-s shud do 6.58.
http://www.edmunds.com/used/2000/acu...648/specs.html
http://www.edmunds.com/used/2002/acu...218/specs.html
whoooaaaa for real??? i was thinkin bout movin to colorado but i didn't know they have cali gas... thought only cali had cali gas. over here iv seen 93 in every state on the east coast for the most part. sorry to hear bout the 91.
B A N N E D
also the altitude sucks for actually making power (we are down like 15-20% on HP
![what](https://acurazine.com/forums/images/smilies/what.gif)
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
