turn signal Question...Must Read..
Old Jul 5, 2001 | 09:30 PM
ha 65mph's Avatar
Old Skool 3.2TL member
Question turn signal Question...Must Read..
In the front corner turn signals we use dual filament bulbs. Does anyone know if the Dim filament goes off when the bright one flashes? I want to swap the wires so the Bright filiment is on all the time when the headlights are on and when it blinks I want the bright filament to alternately go on and off with the dim filament. Anyone done this before?
Evan
Old Jul 5, 2001 | 10:27 PM
Jens
Guest
Posts: n/a
In order to do this will require the use of an auxiliary relay to control the bulb.You will need to wire two relays one for each side.Jens
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Ty-Sama
Sep 21, 2015 05:45 AM
Greengecko
Sep 16, 2015 08:19 PM
