tune up questions
scooooooooore! on the warranty!
figure out if the timing belt water pump job due at 105 was performed
pull a spark plug and see if they are recent
look thru the thread titles on the main section and in Problems and fixes section
our diy guide is here
https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
call acura care usa 1 800 382 2238 x5 register as new owner and ck if any OPEN recalls,
thats ones still needing attention- need cars VIN
Welcome to AZine. I wouldn't hesitate to get a 03 tl-s for the right price. I have been looking for a used car, all junkers out there asking for a high price with high mileage. second gen tl is the best bang for the buck. It is a dream used car if you could get a hold of a decent one. Many owners have high mileage on them and are still going strong.
the engine lifespan is not the problem..fsttyms1 pulled his apart at 200kmiles and it looked new inside
buying a gen2 now is great IF you can get a rightous warranty on the trans
otherwise...have you been playing craps long Sir?? eventually that 7 comes around
Timing Belt and water pump check if those have been done first, if not that is the number one thing you should do first. Then I would do fluids transmission, coolant, power steering, also spark plugs, pcv valve and depending how noisy the valves are you might need a valve adjustment. Also check motor mounts which are common problems. Hope this helps.
joflewbyu2
Oct 8, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
what mileage (& around how much, if you don't mind me asking)?
