trunk question
Old Jun 13, 2004 | 07:50 PM
figueroa1357's Avatar
trunk question
when i press the pop the trunk with the remote u hear like if it open but it donts then i try again and it opens it does this evrey time it but if i use the release on the door it opens on the first time is this normal
Old Jun 13, 2004 | 10:51 PM
HittingDaLine's Avatar
All the way to redline
does that to me too. It seems like a good idea because for us who place the keys in our pockets hitting the trunk button once might happen a few times. So im guessing it was made like that or just hold the button down for like 2 seconds or something like that and it will open as well.
Old Jun 14, 2004 | 07:52 AM
orcaatk's Avatar
If you think about it, having the instant lock/unlock buttons are ok since at worse, you'll either re-lock a "locked" car, or you'll unlock a "locked" car that will then lock itself within a minute or two if no one opens a door. The panic button, if held for the 2 seconds (or however long it takes to activate), will set off the alarm (doors stay locked), but that will shut off on its own if you leave it be (also, if you're in range to set off the panic, you'll probably be able to hear it and shut it off). The trunk, though, can't relock itself if you open it by accident (like the doors can), so if you're walking away from your car and bumped the trunk button (and the button was setup to open instantly), you may not hear it and the trunk would stay open - which is a major security problem. Again, if you bumped the unlock button, the car is unlocked for a minute or two, then it locks itself again. I think that’s why the trunk needs to be pushed, and held, for it to work – just for peace of mind.
Old Jun 14, 2004 | 04:53 PM
2003 tl-s's Avatar
Yes, you definitely have to hold the trunk button down on the remote to get it to open - don't want those accidental openings.
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
datadr
Sep 2, 2015 06:46 PM
