Trouble with using cdr's (Audio)
Old 07-05-2001 | 02:28 PM
amcl's Avatar
Anyone here have trouble with loading cdr's? My 6 disc changer spits it out quite a few times before finally accepting it. It also puts a few scratches on the label side during the process. I'm wondering if it has to do with me using 80min cdr's or that the cdr's i used were labeled for data and not audio.
amcl
Old 07-05-2001 | 02:43 PM
rockinTLS's Avatar
My CD-R's work fine
Mine will not work with CD-RW's. You also do not want to use CD's with stick-on labels. The heat might make them peel off and jam the mechanism.
I have never had problems with my CD-Rs. I use both 74min and 80min types. No scratches noticed either.
The data vs. audio question is interesting. I believe the "session" must be "closed" before it will play in a pure audio CD player. If you record it as "data" that may not be the case.
Hope this helps or at least points you in a useful direction.
Old 07-05-2001 | 03:25 PM
TypeSDragon's Avatar
Loving my 08 TLS!
No problems with mine either since all the cds in there are CDRs, I am too cheap to buy CDs... hehe!!
Old 07-05-2001 | 06:21 PM
amcl's Avatar
I guess this means that my cheap and free 100/spindle cdr's that i got from microcenter are either too thin or too thick.
amcl
Old 07-05-2001 | 06:44 PM
imax's Avatar
Cool Re: Trouble with using cdr's (Audio)
amcl
No problems here. Both the 74 minute and 80 minute CD-Rs work fine for me.
Even CD-Rs my '99 3.2TL didn't like play fine in the TL-S.
Old 07-05-2001 | 06:50 PM
janda_janda's Avatar
what?
Re: My CD-R's work fine
I totally agree - I have never had any problems with the CDR's - + I never use labels. I bought myself a couple of fine-line permanent markers and just write on the cds themselves. Works just fine!
**cringing** at the thought of labels gumming up my player
Old 07-06-2001 | 09:13 AM
oracion's Avatar
Exclamation Re: My CD-R's work fine
Don't use labels. Someone in this forum mentioned about CDs getting stuck in the player because the label peeled off.
Old 07-06-2001 | 12:43 PM
DATA CD-R as specified from the manufacturer, states it for DATA.
Now if you want to use it for your car stereo or home stereo, use a regular CD-R, DO NOT use CD-RW or data CD-R.
Old 07-06-2001 | 12:49 PM
Jacobian's Avatar
CDRs
No problem with CDRs unlike the Alpine I had in my other car. Both 74 and 80 mins play with no problem. Seek times are fast and flawless. I haven't noticed any scratching, loading or unloading problems either.
And unlike the previous poster's comments, I have not had any problems with CDRs that do not claim they are specifically made for audio.
Erik
Old 07-06-2001 | 01:07 PM
imax's Avatar
Huh? I'm looking right a my TDK 74Min 650Mb DATA CD-R blanks that I use for audio; I have never had a problem burning audio CD's while using a "DATA" CD-R. I have been burning for almost 3 years with NO problems.
Old 07-06-2001 | 01:34 PM
bigman's Avatar
'Big Daddy Diggler'
I think its HU w/o the 6 disk in dash that work ok. In order for me to play cd-r's on my 99 i have to use really good quality cd-r's like tdk's or maxell muzic. Other than that i have no problem even if i over burn.
Old 07-06-2001 | 03:23 PM
corey415's Avatar
There actually is no real difference between a CD-R specified by the manufacturer for "data" or "audio" recording. Companies generally label regular CD-r as specialized for "audio" so then can charge a higher price.
As for recording, you can record a CD in Data or audio format. CDs burned in Data format will not play in a cd player. On the other hand, any cd-r burned in audio (WAV) format should work in the car CD player.
08KBP_VA
10-22-2019 02:55 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
Jinkazetsukai
11-21-2015 06:28 PM
navtool.com
31
11-16-2015 09:30 PM
navtool.com
09-25-2015 06:15 PM
Quick Reply: Trouble with using cdr's (Audio)
