trouble starting in non cold weather
Guest
Posts: n/a
I often read about our TL having trouble starting, but those usually came during cold temperatures. Today it was 60s or 70s, humid, showers on and off. It took 4 tries to get my car going, and it struggled to get started that final time. Any thoughts?
what do you mean by not starting...was it not catching...was it turning over...be more descriptive...
1996 2.5 TL Dark Green
HKS Powerflow, HKS Fuel Pressure Regulator, Sebring Exhaust, Jacobs Pro Street, Apex-i AFC, Jet ECU, Powerslot Rotors, Axxis Metal Master Pads, PIAA 1100x, Clarion 9255, Tube Driver Amps, Boston Pro 10's (2) , CD Technologies 6-4-2, Clarion MVA6491 (3), Valentine 1, Cliford Avant Guard 4, Monster Capacitors (2), Jacobs Accuvolt, Trunk, Underdash and Underbody Neons
No nav yet but soon!!!
Do you have any trouble with the Engine Check Ligh?
If you have that issue, then there ain't much you can do but wait for the recall...
I just realized that quite a lot people got this peoblem.. Well, at least most TL owners that I have talked to.....
I've not had that problem yet, even though I live in Florida. But it could have been due to a number of things: 1) Wet ignition system - you mentioned it was raining and humid. 2)Inadvertently "pumping" the gas pedal - not needed with SFI. 3) The recalls for aforementioned "check engine light" or intermittent vapor lock problems. 4)Making sure the gas cap is on at least "3 clicks" tight. If it does it again, check out the easy things above and take it to the dealer if you can't resolve it. FWIW.
I have had problems starting cars when there was a large temp change from the last time the car ran. If it was 60 when the car was turned off and now it is 20 there is going to be a problem. I think the problem is that when you start the car the temp sensors don't boot right away and the computer takes a best guess at what it thinks the temp is. When it guesses wrong you get to crank longer or crank several times.
The way I have found to get around this (with both my old 89 chevy and my 97 nissan) is to first turn the key to run, wait 5 seconds then turn to start. Cranks over nice and fast. I can't comment on Acura since I don't have mine yet. But I also found this to be true on BMW.
Guest
Posts: n/a
Thanks for the responses. It was raining and extremely humid, so I suppose that would be the best guess at this. I did pump the gas pedal, but that was on my final try, and thats what I believe got my car started. Anyways, it had no problems today, thanks again.
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
bearingman07936
01-07-2016 03:22 PM
