trouble loading CD's?
Old Dec 1, 2001 | 06:17 PM
tbone's Avatar
Just got my TL last Thurs. I love it. (2002 TL-S w/ navi)
I've been having a little trouble loading CD's into the changer. I know I'm supposed to hit Load and wait until the display says "load". Sometimes I takes the CD, no problem. Most of the time, it seems to not want to take it and give an "Error" message after a few tries. I definitely don't want to force the CD in there.
I was wondering if this is just a learning issue for me or if other people are having this issue.
Old Dec 1, 2001 | 07:05 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
I used to have this problem too, when I first got the car. What works for me is inserting the cds at an angle.. this is hard to explain, but basically, I put the cds in from the left side. Once I got accustomed to this, it never jammed or refused a cd again.
Old Dec 1, 2001 | 08:56 PM
Guest
Guest
Posts: n/a
I had the same problem that you mention. The solution for
me was what my2sense says about angling the CD's. Basically,
I tilt them down slightly toward the CD player. If you insert
them straight and level, you will get the error. Best of luck!
Old Dec 1, 2001 | 10:28 PM
pianoman41's Avatar
Like everyone else says, the player is sensitive to the angle at which you put the CDs. Unlike rhiannon1207, I found that unless I put the discs in perfectly straight, I have trouble. I found that holding the discs in the center made for an easier feed than holding them by the edges. I was more likely to line up correctly when I grabbed in the center. You'll get used to it in no time.
Old Dec 2, 2001 | 12:24 AM
daverman's Avatar
I've noticed the same thing too, and the solution is the same: insert the CD perpendicular to the head unit's face. That means that you need to tilt the end of the CD that is closest to you upwards.
This is definitely a design flaw: there's an assembly gap right there at the mouth of the CD changer that will entrap your CD's if you don't angle it when you put it in.
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
knight rider
Mar 4, 2016 08:59 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
